Old Apr 19, 2015, 01:53 AM
Stevieraye is offline
Find More Posts by Stevieraye
Joined Apr 2015
Fms t28 cg
Has anybody else had a problem getting the CG on the 1400 mm T28? I finally realized, the correct CG, is 60-65cm from the leading edge of the wing, approx.3" from fuse. So far it's been balanced perfectly with a 3600 Pro Lipo.
Stevieraye is offline Find More Posts by Stevieraye
Old Apr 19, 2015, 04:55 AM
wrongroad is offline
Find More Posts by wrongroad
Australia, NSW, Grafton
Joined Dec 2012
G'day Stevieraye,
Mate I have two FMS T-28's and they both balance at the nominated 80 - 85 mm.
One is a V2 and one is a V3 and they both fly nicely at that.
60 - 65 seems to be a long way out to me. I did cut the foam battery bay at the from to get the CG right by just moving the battery.
Others might disagree with me but I think your CG is too far forward.
Regards and respect
Daryl
wrongroad is offline Find More Posts by wrongroad
Old Apr 19, 2015, 12:06 PM
rcplanenoob78 is offline
Find More Posts by rcplanenoob78
no catchy phrase
United States, AK, Wasilla
Joined Feb 2013
he mentioned 60-65 cm, as opposed to the 80-85 mm you mentioned. This could be why the difference.
rcplanenoob78 is offline Find More Posts by rcplanenoob78
Old Jul 02, 2015, 04:20 AM
CarlBaldock is offline
Find More Posts by CarlBaldock
CarlBaldock's Avatar
Joined Apr 2014
Hi Wrongroad,I have the v3, did you measure your 80-85 mark from where the wing first leaves the Fuselage or from the tapered section in the book it looks like the tapered section.hope you understand what I mean
CarlBaldock is offline Find More Posts by CarlBaldock
Old Jul 02, 2015, 05:43 AM
Joined Dec 2012
G'day Carl,
Mate I measure from the wing joining point to the fuselage.
You can almost do the CG mark with the wing off the model to be honest.
I use a builders set square and that is the easiest way.
I you have any drama with what I am getting at let me know and I will take a photo of how I do it.
I use some small stick on dots to mark the CG spot and if you use the right colours they can look like part of the colour scheme.
Most people do not pick up on the dots.
Regards and respect
Daryl
Discussion Fms t28 800mm motor replacement. AkumaZeto Electric Warbirds 4 Apr 01, 2015 05:39 PM
For Sale FMS B25 1470mm , FMS T28 trojan 1400mm, Dynam Gee bee a jazzmanb Aircraft - Electric - Jets (FS/W) 6 Mar 24, 2015 02:21 PM
Sold Make me Happy and Please buy/ FMS 1400mm T28 FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 1 Feb 16, 2015 09:48 AM
Wanted fms t28 800 mm asteroidguy Aircraft - Electric - Airplanes (FS/W) 0 Feb 04, 2015 08:58 AM
Discussion Park zone t28 vs FMS t28 scrubmonkey Parkflyers 8 Mar 20, 2012 06:53 AM
