Old Jan 07, 2014, 05:05 AM
Maduro is offline
Find More Posts by Maduro
Montecristo for breakfast
Maduro's Avatar
Eden Prairie, Minnesota
Joined May 2004
Help!
Super CP flies for less than a minute per charge
Guys,
I am having very short flight duration times with my Super CP. I just replaced the main board and heli flies fine except the flight duration. I have tried several batteries and have ruled them out. Any help would be greatful.
maduro
Maduro is offline Find More Posts by Maduro
Old Jan 07, 2014, 05:53 AM
thomasprevere is offline
Find More Posts by thomasprevere
Greece, Attica, Nea Ionia
Joined Feb 2011
Originally Posted by Maduro View Post
Guys,
I am having flight duration times with my Super CP. I just replaced the main board and heli flies fine except the flight duration. I have tried several batteries and have ruled them out. Any help would be greatful.
maduro
Check the plug of main motor, all the leads and the mesh of main gear pinion.
thomasprevere is offline Find More Posts by thomasprevere
Old Jan 07, 2014, 07:33 AM
ZeRoEXPO is offline
Find More Posts by ZeRoEXPO
United Kingdom
Joined Dec 2012
Guys,
maduro
Did you have short flight times with your previous main board?
Tell us a little more.
ZeRoEXPO is offline Find More Posts by ZeRoEXPO
Old Jan 07, 2014, 07:40 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Motor might be bad/ Use Genius main gear/ use WK 350ma battery used for Y-6 Scorpion. Or your charger is not right. Batteries might have been run low. Bad batteries will show charge but guess what ? Fights become very short.
dankar04 is offline Find More Posts by dankar04
Old Jan 07, 2014, 01:40 PM
Maduro is offline
Maduro's Avatar
Joined May 2004
I don't think batteries are the problem since I have 12 of them 8 of them all brand new.
Old Jan 07, 2014, 01:48 PM
Maduro is offline
Maduro's Avatar
Joined May 2004
I've also converted to brushless.... and the flying time is shorter than with brushed. But both were terrible for flight time duration.
Old Jan 09, 2014, 09:31 AM
Proud Infidel is offline
Find More Posts by Proud Infidel
9958 gave me the toilet bowl
Proud Infidel's Avatar
United States, IL, Rockford
Joined Jan 2012
Are you using the Genius CP main gear or the Super CP main gear?
Is your brushless motor the C05M motor?
How many teeth are in your pinion gear?
Proud Infidel is offline Find More Posts by Proud Infidel
Old Jan 09, 2014, 10:51 AM
dankar04 is offline
Tucson, Az
Joined Feb 2007
Bet you have a bad charger ? Are you using cheap batteries ? WK 350 25c work fine for me and my Mini is bl. 4 minutes + easy. If you buy el cheapo 240ma's from Bang good/ T-mart good luck. Genius main gear 7t pinion should help. Trying to help but details as usual are lacking.
Old Apr 25, 2015, 12:01 AM
cbatstone is offline
Find More Posts by cbatstone
Joined Jun 2011
Fix it for good - LVC Mod Explained
http://www.rcgroups.com/forums/showt...8#post31442662
cbatstone is offline Find More Posts by cbatstone
Sold Picture link in post SUPER LOWER PRICE *****less than 3 months old: Spektrum DX 7s TX crosby Aircraft - General - Radio Equipment (FS/W) 3 Oct 26, 2013 10:16 PM
Sold FS Feeler: Hyperion EOS 0720i Super DUO3. Latest firmware, used less than a month cfrea Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 21, 2013 11:33 PM
Discussion Recording - less than 44 megabytes per minute anankin Aerial Photography 7 Jul 06, 2011 03:29 AM
Discussion Auto-charging to less than 4.2 volts per LiPo cell Jim_Marconnet Batteries and Chargers 3 Jan 14, 2008 09:02 AM
JR Vigor Flys for 25 Minutes at $3.00 per Flight mardy Batteries and Chargers 6 Apr 28, 2003 04:32 PM
