Old Jan 21, 2014, 04:49 PM
Addicted
United States, CO, Parker
Joined Dec 2011
Question
Stepping up 2S to 3S voltage
I am running a motor and 7.4V 2S battery to keep the Kv lower. However, I want to add a gimbal that works on 11.1-14.8V (3S-4S power).
Would adding this suffice?
http://www.pololu.com/product/2117
Thank you.
Sixinarow is online now Find More Posts by Sixinarow
Old Jan 23, 2014, 04:53 PM
United States, ID
Joined Sep 2011
Somebody just asked the same question. He seemed to think he was going to need a lot more than 1.4A.
http://www.rcgroups.com/forums/showthread.php?t=2070327
My question is... why is a gimbal taking so much power. It doesn't seem to make any sense.
Can you post the gimbal you're using? Knowing the specs would help with a better answer.
jakestew is offline Find More Posts by jakestew
Old Jan 24, 2014, 08:39 AM
Addicted
Joined Dec 2011
Thanks, Jake. I *thought* I saw some gimbals requiring 3S minimum but I see here, on this one http://www.hobbyking.com/hobbyking/s...tors_AXN_.html it runs at 8-9 volts and I will be using a 2S. (This is for a project for a customer that wants me to add a gimbal. Personally, I'd get something better but if it works, then great.)
Old Jan 28, 2014, 04:48 AM
United States, ID
Joined Sep 2011
I don't know what those guys are thinking. No reason for a gimbal to need more than 5v and an amp or so of current.
Discussion I need to step up voltage from 11.1 to 22.2 milo12 DIY Electronics 12 Jan 11, 2014 02:55 AM
Discussion Looking to step up voltage from 11.1 to 22.2 milo12 Multirotor Electronics 1 Jan 05, 2014 10:21 PM
Help! camera step up voltage regulator question snoshoe62 FPV Equipment 5 Dec 16, 2013 05:13 PM
Build Log How to install 2s Brushless in a Parkzone Micro Step-by-Step RcAirplaneNoob Micro Ready-to-Fly 0 Nov 25, 2013 07:25 PM
Found fatshark 2s/3s power filter (2s/3s/4s is ok too) 3d astronaut FPV Equipment (FS/W) 5 Nov 21, 2013 10:36 AM
