Old Jun 03, 2013, 01:37 PM
Joined Jun 2013
2.4ghz transmitter using NRF24L01 transceiver module
My idea is to build a RF transmitter (2.4ghz / 6 ch) using NRF24L01 chip to control mini beetle quad from a pc or arduino.
Is this possible ?
Can any one please provide me some help.
Does all the 2.4ghz transmitters work similarly? or they vary with manufacturer?
FYI:-
My transmitter contains:-
NRF24L01 chip
Arduino board for program
My receiver is mini beetle quad (i dont need to make any alterations here)
debianmaster is offline Find More Posts by debianmaster
Old Jun 03, 2013, 01:58 PM
United Kingdom, Bristol
Joined Aug 2008
Which mini beetle ? Model number.
There are not many NRF protocols been done.
http://www.deviationtx.com/forum/pro...-v202-protocol
http://www.rcgroups.com/forums/showthread.php?t=1564343
SadSack is online now Find More Posts by SadSack
Old Jun 03, 2013, 02:25 PM
Joined Jun 2013
it is V929
http://www.banggood.com/Wholesale-WL...F-p-46046.html this one
Old Jun 03, 2013, 02:40 PM
Joined Aug 2008
most likely wrong about this but sure its not A7105 RF?
Old Jun 03, 2013, 02:45 PM
Joined Jun 2013
im very new to RC, trying to learn.
is it possible to build such transmitter using NRF24L01 if we know the protocol or correct make of the transmitter?
Old Jun 03, 2013, 02:52 PM
Joined Aug 2008
yeah anything is possible just I'd check that your V929 is NRF24L01 and not A7105.
A7105 TX and RX have been done all ready. http://www.rcgroups.com/forums/showthread.php?t=1798913 RX and done have TX link but its in that thread.
Old Jun 03, 2013, 10:58 PM
United States, PA
Joined Feb 2013
Take a look at this thread: http://www.rcgroups.com/forums/showthread.php?t=1833077
Heavy_Duty is offline Find More Posts by Heavy_Duty
Old Jun 04, 2013, 05:34 AM
quax's Avatar
NRW, Germany
Joined Apr 2004
Originally Posted by Heavy_Duty View Post
Thanks a lot for that hint
quax is offline Find More Posts by quax
Old Jun 04, 2013, 03:34 PM
United States, PA
Joined Feb 2013
Do you think the serial communications is viable for this? I don't know much about radio equipment, but I have been looking for a viable way to control many functions, and the traditional method (PWM ?) seems way expensive once you get beyond 9 channels. His serial system goes > 128. He is using the NRF24L01 modules for the transmitter / reciever.
Old Jun 04, 2013, 04:21 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
People still use PWM?!?!? maybe in some "compatibility mode," but for radios it's much nicer to use binary data over a serial link. That's what we do.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jun 06, 2013, 02:24 PM
RC beginner
New York
Joined Oct 2008
the problem with deviating from old and reliable pwm/ppm standards is that everybody uses their own incompatible format. remember the tower of babel?
dave1993 is offline Find More Posts by dave1993
Old Jun 09, 2013, 11:24 PM
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Yep. Welcome to the world of 2.4GHz RC.
Most 2.4GHz chipsets make it way easier to send serial bytes than to send timed pulses. Mainly it's because they're designed to interface with software, not hardware (Wifi, Bluetooth, ZigBee etc..).
With 2.4GHz systems you have more than just the signal format that defines a protocol (and therefore compatibility). How transmitter (and on some systems, receiver) id is assigned (bound) and interpreted may be different. How the transmitter and receiver negotiates what channel (frequency band) to use may be different. How much bandwidth is used may be different (Wifi chipsets use a small number of wide band channels but ZigBee and Bluetooth chipsets use a larger number of narrow band channels). If frequency hopping is implemented, then how the hopping sequence works may be different. The actual modulation of the digital signal on to the radio frequency? The bitrate configured? How often packets are transmitted? Error checking algorithm (if any)? Is burst mode used? Is it raw byte stream (radio modem) or 802.11 or 802.13 link layer?
slebetman is offline Find More Posts by slebetman
Old Jun 10, 2013, 12:50 AM
Inventor&Genius Extraordinary
tune by tito's Avatar
USA, CA, Riverside
Joined May 2006
you can try this application note for the nordic NRF24L01
NRF24L01 this rf ic is easy to program compare to any other device in the market.
tune by tito is offline Find More Posts by tune by tito
Old Jun 10, 2013, 03:05 AM
slebetman's Avatar
Joined Jun 2009
He's trying to make the NRF24L01 communicate with his WLToys V929 quad. Which is something much more complicated than just making the NRF24L01 "work".
Old Jun 10, 2013, 12:18 PM
RC beginner
New York
Joined Oct 2008
Is this possible ?
only if you replace the electronics of the beetle. wlt uses a7105 not 24l01. here are the right threads for what you want:
http://www.rcgroups.com/forums/showthread.php?t=1626362
contrary to popular belief most trancseiver chips cant be simply re-programmed to support alternate protocols. there are built in hardware features that pretty much favor one over the other. imo "universal radio" is a pipe dream. best bet is a cheap bay radio like 9x and set of appropriate modules.
Wanted OrangeRX DSMX/DSM2 2.4Ghz Transmitter Module (JR/Turnigy compatible) Needed jasonyyd Aircraft - General - Radio Equipment (FS/W) 0 Apr 07, 2013 02:20 PM
Discussion OrangeRX DSMX/DSM2 2.4Ghz Transmitter Module (JR/Turnigy) BACK IN STOCK AT HK! mnemennth Hot Online Deals 1 Feb 24, 2013 08:07 PM
Found OrangeRX DSMX/DSM2 2.4Ghz Transmitter Module JR/Turnigy Compatible ivanborrelly Aircraft - General - Radio Equipment (FS/W) 0 Feb 22, 2013 09:10 AM
Discussion Futaba 8FG Super with OrangeRX DSMX/DSM2 2.4GHz Transmitter Module codyrunsfast Radios 9 Jan 12, 2013 07:05 PM
Discussion Use 2.4GHz radio module as data transmitter raute Radios 1 Jan 23, 2012 08:01 AM
