Old Jun 01, 2015, 10:24 AM
paultbg is offline
Find More Posts by paultbg
paultbg's Avatar
Joined Jul 2012
Help!
GPS module burnt?
Hello
I have a GPS module like this one.
It was ok until I have powered the APM in the same time with the USB and external bec (on the digital side) if I remember well. From that point I have no more power led (and obviously no 3d fix led) and is not detected anymore. So I guess is burnt. My questions are:
1. is there any way to save it? Maybe replacing a resistor or something?
2. what to do in the future to prevent this king of mishap?
Please advise if you know. If needed I can take a better picture of the device.
paultbg is offline Find More Posts by paultbg
Old Jun 01, 2015, 10:32 AM
Cereal_Killer is offline
Find More Posts by Cereal_Killer
United States, OH, Columbus
Joined Dec 2014
If you're for sure you shorted it you most likely burned one of 3 parts- a larger input/filter CAP, a protection diode (tho usually those don't burn from just reverse polarity, you would of also had to supply it with to high a voltage) or an on-board regulator.
If you can take some really good macro pic's of both sides we can try to help you more.
Cereal_Killer is offline Find More Posts by Cereal_Killer
Old Jun 01, 2015, 02:47 PM
paultbg is offline
paultbg's Avatar
Joined Jul 2012
pics attached
Probably not the best quality possible but decent hopefully.
Thanks for the help in advance.
Old Jun 01, 2015, 02:57 PM
P.I.Engineer is online now
Find More Posts by P.I.Engineer
P.I.Engineer's Avatar
United States, CA, Redondo Beach
Joined Mar 2005
make sure your apm is pumping out 5v to it first.
P.I.Engineer is online now Find More Posts by P.I.Engineer
Old Jun 02, 2015, 10:39 AM
paultbg is offline
paultbg's Avatar
Joined Jul 2012
I've tried to power the gps even from a ubec with 5 volts, same thing, no lights.
Old Jun 02, 2015, 01:27 PM
Joined Mar 2005
none of the parts look burnt, the only thing that looks weird is that blue rectangle in the middle.
the only not too bad thing is, is that these gps/mag are super cheap these days.
Sold DJI Phantom GPS Module with 4MM GPS Antenna and GPS Booster fdnyfish Aircraft - Electric - Multirotor (FS/W) 2 Apr 09, 2015 09:39 AM
Help! MultiWii i2c GPS with a Remzibi GPS Module liam2317 Multirotor Talk 6 Jun 14, 2013 04:38 PM
Discussion GPS board not detected when GPS module is connected IconFlyer Hoverfly Technologies 17 Feb 15, 2012 04:20 AM
Wanted Openpilot GPS or gps module with TTL output actionplus Aircraft - Electric - Multirotor (FS/W) 6 Jan 25, 2012 02:43 PM
