Old Jun 03, 2015, 02:21 AM
Shane Sunday is online now
Find More Posts by Shane Sunday
United Kingdom, Northern Ireland, Belfast
Joined Jun 2011
Hanger rash is bad enough but a handfull of bad launches has had the nose break off a couple times. Jepes wing mount is fantastic but still not enough to keep the fuse from cracking after a bad launch. The nose on mine is completly epoxy and glassed, the wings as well. The rest is wpb and glass. The wings need epoxy to hold in the washout as they come with washin. You'll want to glass the intakes with epoxy to hold up to many landings so ya... almost the entire model. Don't worry she can handle it. And its well worth it.
Shane Sunday is online now Find More Posts by Shane Sunday
Old Jun 18, 2015, 04:11 PM
Craig Kane is offline
Find More Posts by Craig Kane
Old enough to know better.....
Craig Kane's Avatar
United Kingdom, Northern Ireland, Bangor
Joined Jan 2014
My F-18 finally arrived this evening. Managed to resist opening it up for now but I've got a few days off work coming up and I might just have to check it out
Craig Kane is offline Find More Posts by Craig Kane
Old Jun 18, 2015, 06:19 PM
thedeuce is offline
Find More Posts by thedeuce
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Nice Craig, I had less restraint
thedeuce is offline Find More Posts by thedeuce
Old Jun 19, 2015, 02:58 PM
JetTech is offline
Find More Posts by JetTech
more power=almost enough
JetTech's Avatar
USA, ID, Boise
Joined Sep 2003
Craig, glad you have yours.
I actually took mine out of the box yesterday and started sanding the pieces preparing them for assembly.
Still haven't decided on the color scheme I will be going with.
Good luck on yours and enjoy!
Kerry
JetTech is offline Find More Posts by JetTech
Old Jun 20, 2015, 11:30 AM
Joined Jun 2011
Hey Craig I got mine the same day as you. I opened it as soon as it arrived. I like to check everything is ok. I'm unsure at the moment. I'm considering a 100mm EDF or my turnigy xk4074 B 1400 kv inrunner and an 11X8 prop and 4s lipo. The amps will be high but if I add the sharp trailing edges to the vert and horizontal stabs to trim off as much drag as possible maybe just maybe I can gain some speed with this thing. I'll not start right away but at least I know now what needs re enforced after the first build.
Are you going to post your build here Craig?
Old Jun 22, 2015, 07:43 AM
Craig Kane's Avatar
Joined Jan 2014
Hi Shane,
I will be posting the build on here once I get it started. I'm going for a pusher setup similar to your original one. I'm going to go with the Turnigy 3536/9 910kv with an 11x6 prop on 4s (http://www.hobbyking.com/hobbyking/s...arehouse_.html)
As for colours, I'm looking at the Agressor schemes and I think I'll go for the one in the foreground of the attached picture,
Old Jun 23, 2015, 07:57 AM
thedeuce is offline
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
The aggressor scheme will look great. I thought of that as well at one point.
Old Jun 24, 2015, 10:38 AM
Joined Jun 2011
Hey fellas. I've reread most of this thread again there are so many of us building this thing yet so few videos of us flying it. Lessram how is the build coming along? Deuce have you got any video? Craig that agressor scheme will rock look real mean in the sky. looking forward to more builds, more flights, more fun.
Old Jun 24, 2015, 05:37 PM
thedeuce is offline
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Shane,
I have a big flying weekend coming for me in July. Will have video of it then. Will play around with wing cams as well. When I get time to fly the weather hasn't been the best. Still too early in the season for stable weather.
Old Jun 25, 2015, 08:59 AM
JetTech is offline
JetTech's Avatar
USA, ID, Boise
Joined Sep 2003
You guys that have put retracts in this plane, I have a question for you.
What retracts are/did you use?
I want to use electric retracts and need to know what has worked well so I don't have to re-invent the wheel.
Kerry
Old Jun 25, 2015, 09:34 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
I got these: http://www.hobbyking.com/hobbyking/s...Oleo_Legs.html
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jul 02, 2015, 10:57 AM
Craig Kane's Avatar
Joined Jan 2014
Started getting the parts together to fit out the F-18.
Bought this pilot from Hobbyking. Maybe a little bit too large for scale but I think it looks the part.
I'm going to do a bit of detailing in the cockpit and add an ejection seat and instrument panel.
Old Jul 02, 2015, 01:19 PM
JetTech is offline
JetTech's Avatar
USA, ID, Boise
Joined Sep 2003
Pilot looks nice!
Discussion KMP ParkPilots F-18 thedeuce Foamy EDFs 5 Oct 07, 2012 11:20 PM
Discussion Kmp f-18 Roguemonkey Electric Ducted Fan Jet Talk 10 Mar 10, 2011 11:54 AM
Discussion KMP Glass F-18 splais Electric Ducted Fan Jet Talk 14 Feb 04, 2011 06:41 PM
Sold EJF/KMP F-18 foam bruff Aircraft - Electric - Jets (FS/W) 5 Aug 07, 2007 01:31 PM
Discussion Kmp F-18 Eps Foam Edf Jet PREACHHAMES Foamy EDFs 120 Feb 20, 2007 08:28 AM
