Old Jun 06, 2006, 02:37 PM
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Build Log
F86 Sabre, home brewed
I've been admiring Scott Black's F86 for a while now but decided against it as it requires a bungee. I decided I don't like the K&A F86 park flier because of its small size. The only other option is to roll my own.
My F86 will have a 48" WS, about 360 sq.in. wing area. Power will be a Ky T33 fan driven by a HET Typhoon 2W on a 2S2Px2600 LiPo. I'm predicting an AUW of ~42 oz for a wing loading of 16.8 oz/sq.ft.
Like my other EDF's, this F86 will be designed for hand launch, small field flying.
To date I have about 6 hours in drawings, another 4 in ribs and formers.
Since it is summer and the livin' is easy, I probably won't do a whole lot of building everyday so I'm guessing it'll be a slow build. Unless we have a rainy summer.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Jun 06, 2006, 05:57 PM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I'm on-board, Larry!
Steve
St. Martin is online now Find More Posts by St. Martin
Old Jun 06, 2006, 07:21 PM
that tree ate my plane
rotccapt's Avatar
oklahoma city oklahoma
Joined Apr 2004
sounds good will there be plans posted
rotccapt is offline Find More Posts by rotccapt
Old Jun 06, 2006, 08:33 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Yup, I am locked in...
Eric B.
AirX is offline Find More Posts by AirX
Old Jun 06, 2006, 09:13 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
On deck!
Scott
Old Jun 07, 2006, 12:18 AM
go fly! no crashes!
Synwpn's Avatar
Honolulu, HI
Joined Jun 2003
signing in.
David
Synwpn is offline Find More Posts by Synwpn
Old Jun 09, 2006, 07:48 AM
Joined Sep 2000
rotccapt,
My goal is to build a flyable plane, not generate beautiful drawings. Thus my "plans" are the absolute minimum needed to build and there are no instructions. My drawings are a combination of CAD and hand drawn. If I can print a full size component on 8.5 x 11 paper, I use CAD. Otherwise I draw it the old fashioned way.
As I build, I try to revise the drawing to the latest as-built status but sometimes I'll miss a detail here or there. And much is left to the builder' imagination.
I have sold plans to others. The cost is whatever KINKOs charges to copy plus postage, usually around $20. I prefer to sell plans only after the plane has been flown. On my last home grown design (F9F Panther) I supplied two others with the plans before the plane was flown. I did follow up with them concerning the final balance point once I had her dialed in.
Old Jun 09, 2006, 09:53 AM
unclecrash's Avatar
white lake michigan
Im signing on to watch your build. Dave
unclecrash is offline Find More Posts by unclecrash
Old Jun 09, 2006, 11:57 AM
aspiring 3D Killer
PDX
Joined Jun 2005
Larry :
I'm all eyes
Chris
bentwing is offline Find More Posts by bentwing
Old Jun 09, 2006, 03:40 PM
flo
flo's Avatar
Near Munich Germany
Joined May 2003
Hi Larry
signing in.
good luck with it.
flo
flo is offline Find More Posts by flo
Old Jun 11, 2006, 01:48 PM
Joined Sep 2000
Limiting my building time to after 10:00 PM and a rainy/windy Saturday morning, I built the wing panels. Ribs are 1/16" balsa, top and bottom spars are 1/8 x 1/4 spruce, shear webs are 1/16" balsa, LE is 1/2 x 3/4 balsa and the TE's are commercially available 1 1/4 x 1/4. The TE's had to be built up to match the curve of the 12% Clark Y. About 6 hours for the two panels.
Old Jun 15, 2006, 02:58 AM
aspiring 3D Killer
PDX
Joined Jun 2005
Larry any Progress? It must be abut ready for the Maiden by now
Old Jun 15, 2006, 09:30 PM
Joined Sep 2000
I have reached a critical juncture in the F86 build. I am at the point where I need the Kyosho T33 fan so I can mount it into its former. My problem is the T33 fan is still in the T33.
My T33 is a very much flown air frame, full of dings from too many bellyslide landings. Both wings are broken, literally held together with packing tape. The balsa front end is cracked in a few places, the wing mounting plates are loose, again relying on packing tape to hold it together. In short, the T33 is a real mess. But she still flies well.
Taking it apart for the fan is the best thing I can do for it. But this T33 has been a part of my R/C experience since April of 2001. I just can't seem to pull the plug and let it die with dignity.
So until I can canabalize the T33, progress will be slooooow.
Old Jun 15, 2006, 09:49 PM
unclecrash's Avatar
white lake michigan
Bring it over I will shoot it for you and put it out of of its missouri so it does not have to suffer while you pull its guts out By the way shes lookin good. Dave
Old Jun 16, 2006, 12:32 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
So..PM me your addy, my loosing haired brother.. and I'll ship you a shroud and un-used rotor. Sorry no spinner..
Steve
Watt-age F86 Sabre george jetson Electric Ducted Fan Jet Talk 7 Aug 15, 2002 11:52 PM
Need help with F86 Sabre XSthrust Electric Ducted Fan Jet Talk 0 Aug 11, 2002 07:30 AM
Yippee! FS-Home Brewed FH sailplane raceredg Aircraft - Sailplanes (FS/W) 0 Jul 27, 2002 09:17 PM
New Home Brewed DLG Acer Electric Sailplanes 18 Jan 18, 2002 06:45 PM
New Home Brewed DLG Acer Electric Plane Talk 6 Nov 13, 2001 03:54 PM
