Old May 24, 2015, 08:17 PM
BeyondHypojermia is offline
Find More Posts by BeyondHypojermia
United States, CO, Colorado Springs
Joined May 2015
Wrong servo for drifting?
Hey everyone,
Picked up a Team Associated TC3 off Craigslist today. The guy said the servo was tame so I'm wondering if that's why I can't get it to drift? I'm new to cars so I'm not sure if it's underpowered or if it's a problem with something else? The servo is a GWS S03T STD. Other specs are:
Reedy brushless motor (doesn't specify the model)
LRP F1 ESC
I'll attach a pic too. Thanks for any help or advice!
BeyondHypojermia is offline Find More Posts by BeyondHypojermia
Old May 25, 2015, 01:13 AM
SoloProFan is online now
Find More Posts by SoloProFan
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Are you using drift tires? It looks like you got rubber "boots" on, and that means you can probably only drift on ice or wet surface.
SoloProFan is online now Find More Posts by SoloProFan
Latest blog entry: Pictures of various boats
Old May 25, 2015, 04:59 AM
BigBadDogg is offline
Find More Posts by BigBadDogg
United States, MI, Wyandotte
Joined Dec 2014
a servo has nothing to do with a rc's ability to drift its the drive train. motor esc battery TIRES.. get a set pf drifting tires and get back to US.
BigBadDogg is offline Find More Posts by BigBadDogg
Reply With Quote  (Disabled)
Old May 25, 2015, 09:51 AM
Joined May 2015
Ok thanks, I'm thinking it might be an underpowered motor because it does drift a little in reverse. It's just not very fast or reactive. It doesn't go fast enough to even skid when entering a turn.
Old May 25, 2015, 01:33 PM
cbaker65 is offline
Find More Posts by cbaker65
cbaker65's Avatar
Joined May 2015
Lol...+1 on what was said!..Im not a drifter nor is none of my street rides.
An they dont have special tires or servo,but they will drift on demand,
an on their own.
So its like what was said,not enough torq,an not the right tires...
cbaker65 is offline Find More Posts by cbaker65
Old May 25, 2015, 02:40 PM
Joined Dec 2014
Try a set of these .. as for motor drifters dont wanta run at high speeds its a controlled wheels spin and steering control ..http://www.ebay.com/itm/3Degree-Drif...575?rmvSB=true
Old May 25, 2015, 04:00 PM
Joined May 2015
Cool, will do. Thanks for the input!
Old May 28, 2015, 03:45 PM
LemonC is offline
Find More Posts by LemonC
Joined Jul 2014
drift tires! i have a touring car (sakura xi sport) all i did to make it drift was to use drift tires. there are a few different materials the manufacturers use, but if you are just trying to drift on concrete, most should work (some will wear faster than others).
If you plan on running lots of camber, id get the angle'd drift tires so you get a bit of decent/even wear out of them.
my first set were strait but after setting a bit of camber they wore through on the insides too fast.. i use angled now.
Also, you could probably gear your tc3 to drift in your rubber tires altho i would not recommend it because you will burn through them in 1 session more than likely.
all the rc drifting videos you see, they are using drift tires, not standard rubber tires. and id just start off with some cheap ones bc they wont last forever anyway.
LemonC is offline Find More Posts by LemonC
Old Jun 03, 2015, 02:58 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
As it's been said, you'll need hard plastic drift tires.
Just a slight clarification, that's a brushed motor not brushless.
wparsons is offline Find More Posts by wparsons
Old Jun 05, 2015, 10:00 AM
Jonb81 is offline
Find More Posts by Jonb81
Smooth is Fast
United States, CA, San Diego
Joined Sep 2008
I don't drift but. You want a servo that centers quickly if you want to transition drift (i.e tie them together). Also you want to go with a brushless system in time. The motor that most guys run is in the 10.5 range. Also they like to under drive the front to allow the car to slide the rear more. When you under drive you are turning the front wheels slower than the rear. Hope this helps.
Jonb81 is offline Find More Posts by Jonb81
Help! Wrong Screws for D654 and A107 MG Servos mchldpy HobbyPartz.com 4 May 20, 2014 12:55 PM
Discussion Flap going wrong way, reverse servo travel? Platfox Radios 16 Feb 15, 2014 07:08 PM
Discussion Wrong "trottle puls" temperatur drift?! V_Okto Eagle Tree Systems 1 Feb 11, 2013 02:47 PM
Wrong Servo for my heli... need help please! tangal98 Micro Helis 3 Dec 16, 2005 04:15 PM
Wrong servos for Hitec equipment ? Al P Electric Plane Talk 5 Jul 22, 2002 02:21 PM
