Old Aug 24, 2012, 04:52 AM
Tovin is offline
Find More Posts by Tovin
Joined Aug 2011
Turnigy TGY-113MG Digital servo
Just received the new digital metal servo from HK.
It is the best performance @ $8 price range digital servo I had try till date.
http://www.hobbyking.com/hobbyking/s...0_10s_12g.html
Tested side by side with Emax ES08MD, TGY-113MG speed is slightly faster & resolution is much better than ES08MD.
Think EMAX is over rated for its spec.
I did open the TGY-113MG for inspection, it output pot having different design which I don't quite understand although it is still using the same potential tech.
The metal gear in it is very precise consider at this price.
However not sure the durability for this new servo, as I notice the motor operate at higher temperature at high stress/torque conditions.
Anyone got to try this new servo please share your experience.
Tovin is offline Find More Posts by Tovin
Old Aug 26, 2012, 11:04 AM
Tovin is offline
Joined Aug 2011
Apparently, this is same as KST DS113MG servo.
Not sure why Hobbyking label as made in Taiwan? as KST is made in China!!!!!!
However Hobbyking is selling @ below $8.
Old Sep 30, 2012, 02:50 AM
Brush Hog is offline
Find More Posts by Brush Hog
United States, NC, Smithfield
Joined Jul 2012
Did you end up using these servos? how have they held up and whats your opinion of them?
Brush Hog is offline Find More Posts by Brush Hog
Old Sep 30, 2012, 08:57 AM
2Doggs is offline
Find More Posts by 2Doggs
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
@Tovin, the HK site shows the "F" dimension as 28mm, whereas the overall height is 31mm. Other mini servos like the Corona etc have F = 21mm. Can you check it on yours?
Are the mounting lugs solid, or are they hollowed out on the underside?
These look quite promising for cyclic on a 450 Pro, even if the F dimension is 28mm. If it's actually 21mm or so, they should work on other 450's too.
2Doggs is offline Find More Posts by 2Doggs
Old Oct 01, 2012, 07:09 AM
Tovin is offline
Joined Aug 2011
Its same size as Turnigy TGY-306 servo from visual view.
Mounting tab is solid not hollow.
The cyclic control feels more accurate than Emax digital servo.
However its still having some play from its metal gear inside.
I had install on Tarot sport450 flybar version, did improve on the cyclic control.
Tgy-306 still better, no play & high speed.
For $8 servio this is the best digital servo I had try, better than expensive Henge servo.
Old Apr 21, 2015, 04:07 PM
andriesa84 is offline
Find More Posts by andriesa84
Sassenheim, Netherlands
Joined Jan 2010
Just crashed a 1100 gr 3D plane because the 113 on the elevator couldn't handle it.
Pretty disappointed in the torque of this servo, it couldn't even handle pulling it out of a fast loop, using the standard servo arm!
andriesa84 is offline Find More Posts by andriesa84
Old Apr 24, 2015, 07:29 PM
Tovin is offline
Joined Aug 2011
I had remove all 113 as it has quality issues, never survive if crashed.
I only use it for scale slow flying & cheap built aircraft.
Discussion Turnigy TGY-A55H Alloy Case Digital Slim Wing Servo xvis Slope 8 Aug 24, 2014 08:27 AM
Sold Turnigy TGY-1800A Micro Servos (NIP) AzHeliCrasher Aircraft - General - Radio Equipment (FS/W) 3 Jul 20, 2012 10:38 PM
Sold 3 Turnigy TGY-930 servos SOLD!!! cap231ex Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 09:33 PM
Sold 5 Turnigy TGY-1800a Micro servos coptersrcool Aircraft - General - Radio Equipment (FS/W) 2 Feb 28, 2012 12:35 PM
Help! Turnigy TGY-1600A Servo Problem? Fredriksson Radios 1 Oct 01, 2010 09:37 PM
