Old Jan 31, 2015, 12:19 PM
moxieman3864 is offline
Find More Posts by moxieman3864
moxieman3864's Avatar
Joined Aug 2013
Esc question
Hi to all fellow hobbyist i was wondering can i use 3 Afro ESC 12Amp Ultra Lite Multi-rotor Motor Speed Controller (SimonK Firmware) Version 3
Specs:
Current Draw: 12A Continuous
Voltage Range: 2-4s Lipoly
BEC: 0.5A Linear 5.0v
Input Freq: 1KHz
Firmware: afro_nfet.hex
Discharge wire/plugs: 20AWG/Male 2mm
Motor wire/plugs: 20AWG/Female 2mm
Weight: 10g (Included wire, plug, heat shrink)
Size: 25 x 20 x 6mm
with 1
Lumenier 12 amp ESC with SimonK Firmware
Specifications
Max continuous load: ~11 amps
Burst Current: 16A/10sec
BEC: 5v/1amp max
Lipo Cells: 2 to 3 cells
Cables are fitted with female 2mm bullet connectors
Weight: 10g
any help would be well appreciated !
moxieman3864 is offline Find More Posts by moxieman3864
Old Jan 31, 2015, 01:20 PM
reelflyt is offline
Find More Posts by reelflyt
reelflyt
Edmonton, Alberta, Canada
Joined Mar 2010
Hi.
The board doesn't know what esc you are using , and it shouldn't have any problems with one odd esc as long as they are the same voltage range . One time I blew a esc and didn't have the same type (amperage ) So I replaced it with a larger one on my quad . Didn't make any difference in flying .
Gordon
reelflyt is offline Find More Posts by reelflyt
Old Jan 31, 2015, 04:50 PM
Joined Aug 2013
thnks for the feedback reelflyt i guess i'll give it a try
Question Brushed Motor ESC Power Capability Question Sympster DIY Electronics 1 Sep 27, 2014 09:30 PM
Discussion Cheap Brushed ESC question fargophil Electric Power Cars 10 Sep 26, 2014 07:46 PM
Question ESC Question - Dead Battery with Throttle Off? pomroyj Power Systems 13 Sep 23, 2014 09:52 PM
Discussion esc question walter3rd Power Systems 3 Sep 23, 2014 02:48 AM
Discussion BEC/ESC question for F450 with Opto ESC's. dpgfla Multirotor Power Systems 0 Jan 15, 2014 07:02 PM
