Old Jun 23, 2008, 05:49 PM
GGRN is offline
Find More Posts by GGRN
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Build Log
Scratch built Gws Edf 50 Me 262 Schwalbe thread
Hi guys !
Here's a new buildthread about the Messerschmitt 262... I know it's not the first, but this one is a so nice flyer... I couldn't resist.
I designed her to be easily flyable and to allow (almost) everyone to fly it without "steelnerves". The first one i built 4 years ago used the brushed motors version of the GWS EDF 50, so she was underpowered and motors lifetime was very short (like the real one...). When brusless motors like Feigao 1230 were available, i decided to build a new one, and i was not desappointed : She was just like i wanted, with a nice scale looking, enough power, reliability, lightweight and good flying characteristics. She's not supersonic, and only needs cheap equipments.
Let's see some specs :
WS : 1100 mm (43,3")
WA : 18,5 dm2
W : 555 grams (18,69 oz)
WL : 30g/dm2
controls : Throttle, ail., elev. (rudder is possible and recommanded)
2x GWS EDF 50 (2x3x3 rotors), 2x Feigao 1230 5300kv, 2x Castle creations Thunderbird 09, 3s1p TP 1320 mA.
Downloadable plans here : http://www.parkjets.com/me-262.html
Video : http://www.rcgroups.com/forums/showt...3#post11276951
GGRN is offline Find More Posts by GGRN
Old Jun 23, 2008, 05:51 PM
68Strat is offline
Find More Posts by 68Strat
Registered Triplane Addict
68Strat's Avatar
Winchester MA
Joined Jun 2004
really really gorgeous!
68Strat is offline Find More Posts by 68Strat
Old Jun 23, 2008, 06:02 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Thanks 68Strat ! I've to confess i'm not displeased with the result. Hope it'll be poss. to show a video soon (as soon as i can get a cameraman)
Old Jun 23, 2008, 06:08 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
As usual, the airframe is out of 3 mm Depron, with use of foam blocks, 6mm deprons, 0,4 mm plywood and 3 mm balsa in some places. The main preoccupation during this build is to save weight everywhere it's possible to get the best Thrust/Weight ratio and wingload. There's no power to spare, so it's a good thing to keep an eye on the scale...
Of course, it'd be possible to overpower it with a pair of microfans and razor 300, for ex. But it'd be essential to reinforce the structure with a sandwich balsa/carbon:balsa spar and hard balsa leading edges, and to change thrustline by adding 1 downthrust.
Old Jun 23, 2008, 06:14 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
The first step of the build is cutting all the pieces from 3 mm Depron : Formers and basis.
Old Jun 23, 2008, 06:22 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
The upper fuselage is built first. Formers are glued on the basis before glueing the rear fuselage skin panels between formers F5, F6, F7, F8.
Old Jun 23, 2008, 06:52 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Nose cone curves are made with small 3mm depron stripes glued between formers F1 to F5... this method will remember something to those who are used to balsa works... Don't worry, it's not so long it seems to be !
Old Jun 23, 2008, 07:05 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Vertical fin is built before to be glued on the rear part of the basis (beware of angles, and don't forget the elev. pushrod !). In this step of the build, you'll have to decide if you want the rudder control suface... I've just one thing to say : I miss it on mine !
Before starting on the construction of the lower fuselage, don't forget to draw the stab. location and incidence (0), it's the best moment.
Old Jun 23, 2008, 07:07 PM
Jorge Fernandez is offline
Find More Posts by Jorge Fernandez
Guadalajara, Jalisco, Mexico
Joined Mar 2004
Extraordinaire
Bravo GGRN:
I am a big fan of your work.
Please keep more photos coming!
Jorge
Jorge Fernandez is offline Find More Posts by Jorge Fernandez
Old Jun 23, 2008, 07:15 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Thanks Jorge ! I'll do my best !
Old Jun 23, 2008, 07:20 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Of course, the lower part of the fuselage is built using the same ways as for the top. The main difference is the battery tunnel in the nose cone. With holes everywhere for battery cooling.
Old Jun 23, 2008, 07:26 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Lower part of nose cone is also built by glueing 3mm depron stripes on formers F1 to F5
Old Jun 23, 2008, 07:29 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
A small foam block is glued and sanded in end of the nose cone construction.
Old Jun 23, 2008, 07:31 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Work on the rear part of the lower fuselage (there's a vertical sheet of 3 mm Depron between F7 and F8 formers)...
Old Jun 23, 2008, 07:34 PM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Because of the small radius, work on the tail cone is a bit different : Two sides are glued first. Then, the bottom (2 x 6mm Depron is glued and sanded.
GWS edf 50 fan jeffhines Electric Ducted Fan Jet Talk 6 Jan 14, 2002 12:24 AM
GWS EDF 50 Designs Ralph A. D'Amelio Electric Ducted Fan Jet Talk 7 Dec 03, 2001 09:43 PM
GWS EDF 50 Fried?? Bleriot Electric Ducted Fan Jet Talk 1 Nov 27, 2001 09:13 PM
GWS EDF-50 in Europe? Tyson Parkflyers 9 Nov 16, 2001 04:29 PM
Who has GWS EDF-50 in-stock? Kolchak Parkflyers 2 Nov 15, 2001 10:52 AM
