Old Nov 01, 2012, 05:41 PM
Joined Dec 2007
SDZ 22 Mucha Standard
I built a Mucha Standard scale 1/4.
I use a HQ 2.5 12 airfoil.
The original Airfoil on the K. Nietsher plan scale 1/5 is a Clark Y.
I think that the HQ will be a better.
aurectar is offline Find More Posts by aurectar
Old Nov 01, 2012, 05:42 PM
Joined Dec 2007
Look at this Video.
http://www.youtube.com/watch?gl=BE&v=i3gHw4Kdoz4
Old Nov 01, 2012, 09:56 PM
United States, KY, Taylorsville
Joined Mar 2010
Very nice bird! I like the launch!
ARUP is offline Find More Posts by ARUP
Old Nov 02, 2012, 02:19 AM
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Cool, I was flying a 1:1 in 1974 to 1976.
Nice feeling on the steering surfaces, and aerobatic too
+ 5 G
And the local gliderclub still fly one.
I would also go for the HQ
Regards
S
SpeedsterDEN is online now Find More Posts by SpeedsterDEN
Old Nov 22, 2012, 03:02 AM
Berlin, Germany
Joined Mar 2002
Well, the good old Clark Y is not that bad!
A Mucha has narrow tips, which means low Re numbers in 1/4. The HQ does not like low Re numbers. It might not be a serious problem on a build up wing because you will not have a long laminar flow, but in this case you will not have the theoretical performance of the HQ! In the real conditions the Clark will be much better than the polars suggest.
What is the estimated weight?
Viktor is offline Find More Posts by Viktor
Old Nov 23, 2012, 12:24 PM
Joined Dec 2007
I think 5000 a 6000 gr
The wingtips are 130 mm.
A clark y is surely not a bad choise.
But is some conditions, a HQ 2.5 12% is better.
By heavy aerotows, specialy when 100cc engines or more are use.
In this case a clark y have less stability in faster speed.
Old Jan 20, 2014, 01:01 PM
Joined Dec 2007
in town
My Mucha builder is back in town.
Old Jan 20, 2014, 01:06 PM
Joined Dec 2007
Last evolution
My Mucha begins have his form.
Old Jan 20, 2014, 01:14 PM
Joined Dec 2007
recent
An other pict of the recent evolution.
For the connection of the tailwing I use two carbon tiges 6mm diam
Aurectar
Old Jan 26, 2014, 06:05 AM
Joined Dec 2007
Covering the fuse with hardbalsa strips as you can see on the picture and sketche.
The layers in red are spruce.
It seems very robust.
The glider on the background is the little brother of the Mucha with the name "Astroflight-Monterey"
Sorry, my nowledge of the englisch linguage is not very exelent.
I hope that you can understand my.
Old Jan 26, 2014, 10:01 AM
Florida
Joined Jul 2004
Aurectar the build looks great! What plans or kit are you building from?
You English is good enough, we can understand. The Monterey looks great!
Cheers!
Thermaleer
Thermaleer is offline Find More Posts by Thermaleer
Old Jan 26, 2014, 04:13 PM
Joined Dec 2007
Cheers!
Thermaleer
I use a Klaus -Nietser (famous german model-glider designer) plan as inspiration.
This design have a good concept but not very accurate.
The original disign have a wingspan of 3000 mm.
The model I build a wingspan of 3750 mm.
I have have make some personal upgrades at the original K.N model.
This result in a other more accurate design.
The most important changes are
-other wingspan (bigger)
-other wingsection (profile)
-Stronger construction.
- more exact scale (for example the nose)
This is a total scratch project.
Every piece i have make on grand mothers manner (old scool)
No cadcam and no laser Cut.
For more information
http://www.modelbouwforum.nl/forums/...tandard-7.html
Cheers,
Aurectar
Old Jan 26, 2014, 04:34 PM
Florida
Joined Jul 2004
very nice indeed!
Old Mar 05, 2014, 02:57 PM
Joined Dec 2007
sanding
[IMG][/IMG]
The fuse have his definitive form after sanding the workpiece.
The provisore canopy is a bloc of styropor sanding in the form of the real-scale.
Good observation of the form is the question.
Compare the form of the nose with the same model in the other threat ( szd 22 mucha standard 1:4) and look to the nose of the real-scale.
Cheers,
Aurectar
Old Mar 05, 2014, 04:21 PM
Joined Dec 2003
My Mucha
Aurectar
Looks really good!! You should be VERY proud of your scratch build.
I am looking for a set of full scale plans. Did you design your Mucha from a set of full scale plans? I would be willing to buy outright a set of copies or trade a set of your copies for a full scale set from my collection of copies.
This is the only kit I handle that was not designed from full scale plans.I understand a full scale ship was used for measurements, though.
Cheers
Jim aka vintagersailplnr
PS: Post more pics as you progress, please!
vintagesailplnr is online now Find More Posts by vintagesailplnr
Discussion SDZ 37/ Cobra 15 mack5 Scale Sailplanes 1 May 01, 2012 10:43 PM
Sold 4 - E-flight Standard Servos $22.00 rdcskkrose Aircraft - General - Radio Equipment (FS/W) 3 Dec 10, 2010 07:48 PM
szd 22 mucha standard 1:4 41fabio73 Scale Sailplanes 9 Jan 01, 2010 04:24 PM
Discussion Mini vs Standard Servos, .40 size F-22 PTS? DannyZRC Radios 1 Jul 19, 2009 04:02 PM
