Joined Oct 2012
Boomerang .60
Hi guys,
As my eyesight is aging I need a bigger trainer, and I'm thinking of a Boomerang .60 converted to electrickery. I'm leaning towards installing this redback .61 motor and esc, and running it on 4s. Do you think it's enough or should I go bigger? |
But pick the prop you want to use first, then decide on Kv and cell count. |
United States
Joined Feb 2001
With that motor and ESC you should start with a 6s LiPo and APC 13x6.5e prop. Choose the LiPo MAH for the correct cg. Maybe a 5s LiPo would be ok with a larger prop but I think that 4s is too low voltage for a 60 size airplane. . |
Joined Oct 2012
At the risk of sounding like I should be on another type of web site, about 8 1/2 inches ![]() Smokey |
So let's assume you're looking at about roughly 800W input poweras a target, with a minium of 700W . You can get 800W on 4S pulling about 800/14.8=54A, on 5S @ 43A or 6S @ 36A
It also means from a power handling point of view, ignoring weight and balance for the moment, that minimum motor weight should be about 270g, based on average motors comfortably handling 3W input power per gram motor weight. But depending on where you can mount the battery, you may find a motor a lot heavier than 270g helps with balance without resorting to lead weights. Assuming decent efficiency of 80%, 800W in will be 640W at the prop. That will spin a 14x7 prop at about 8300rpm, or a 15x8 at about 7000rpm. In both cases, that is enough for a pitch speed of about 60mph - about right for a big slow trainer As you can use a 15" prop, you could manage with 4S using a 15x10 with the Turnigy G46-550 for about 750W in, or the G60-500 for about 720W in( also 15x10). Go to 6S, and the G60-400 and 15x8 are an option for about 820W, or for a bit of overkill around 960W if you wanted to stretch to a 16x8 . The G60-500 gives a lot of flexibility, eg on 5S from 700W in with a 14x7 to 950W with a 15x8, or on 6S with a 13x6.5 for about 850W. That might seem like a lot of options, but the next thing I would be doing is look at where I can put the battery pack and how much space there is for it. Once you know what sort of pack fits and how balance is starting to look, motor size and Kv largely follow along. |
Joined Oct 2012
Thanks mate, some of that sounds like double dutch to me, but it gives me something to research ![]() It'll fit a 6s 5000mah pack (about 850grams) fairly easily. |
| Thread Tools | |
| Discussion Boomerang 40 vs. Boomerang 60 | jpleaner | Beginner Training Area (Fuel) | 0 | Sep 16, 2012 08:36 PM |
| Discussion Seagull Boomerang 60 and OS OMA-5020-490 | BennyLaird | Glow to Electric Conversions | 16 | Sep 13, 2012 06:09 AM |
| Question phoenix models boomerang 60 trainer | mrleenagle | Fuel Plane Talk | 3 | Aug 18, 2009 10:12 PM |
| Question Noob Alert! Power System for Boomerang 60? | jackc | Power Systems | 4 | May 12, 2006 10:51 PM |
| Question Electric Power for Boomerang 60 ARF? | jackc | Electric Plane Talk | 1 | May 03, 2006 06:01 AM |
