Congrats on your conversion. That`s what they should have built in the first place, with the proper shaping and molding to feed the fan. It sounds like you don`t need any more thrust, based on the takeoff.
If you are looking for more speed, I`d suggest you stay with the 80mm fan, but go with a more aggressive rotor, like the new one piece 12 blade 90mm rotor. Then cut it down to fit the 80mm shroud. This will bring your power up and your efflux speed will be faster, but thrust won`t increase much. That`s what you want. If you go with the 90mm, you will have more thrust and lower efflux for the same amount of power that you push thru the 80mm. So you may be able to hover it, but it won`t be any faster. So I`m logged in. get us some video if you can. Good luck, Lee PS...also drag reduction will go a long way too. Now that you don`t have the prop to worry about, you might think about cleaning up all of those draggy fins on the bottom of the wing. It will still fly great and will be much cleaner. |
Latest blog entry: EDF, My First Six Years, mostly Pictures
Carbon-Z Scimitar EDF Conversion maiden flight
This was the maiden flight, was only flown on lower rates in the video. Plan on making a better video showing more of what this plane can do.
The video link doesn`t work. Maybe you have it marked private.
Looks like it flies great. Clean up that bottom and add some etracts and you`ll have a very slick edf. You should be able to run a shorter efflux tube too. 6" is plenty, I don`t care what the girls say.
| Thread Tools | |
| For Sale Carbon Z Scimitar w/retracts | Challe923 | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 20, 2013 07:25 AM |
| For Sale Carbon-Z SCIMITAR BNF [LPU] 150.00 | xlrDALLAS | Aircraft - Electric - Airplanes (FS/W) | 9 | Jan 30, 2013 10:04 PM |
| For Sale Carbon-Z SCIMITAR BNF [LPU] 150.00 | xlrDALLAS | Aircraft - Electric - Airplanes (FS/W) | 0 | Jan 07, 2013 05:46 PM |
