Old Sep 29, 2015, 06:55 AM
Berkie is offline
Find More Posts by Berkie
A life of Lucking Fuxury
Berkie's Avatar
Australia, VIC, Rosebud
Joined Feb 2007
Fantastic polymorph
Haven't tried this brand, but Polymorph is great for reinforcing the inside of foamy cockpits
Pour the whole container into an electric frypan, cover with water and heat to 70c until it is completely transparent.
Cover with non stick baking paper both sides and roll out with a rolling pin. Cut to sections, place again on non stick baking paper and heat with a heat gun until transparent and soft like play dough. Then hold it in a piece of baking paper(its bloody hot and sticky) and thoroughly work it into say, the cockpit.. If it lifts later, just apply some hotmelt under it and squeeze down.
You can also get varying thicknesses by using a little pasta making machine. Just make sure the polymorph is hot enough and covered both sides in baking paper.
It will set as hard as nylon. Can be drilled and sanded.
I had a high speed crash in which there was NO damage at all to the cockpit. The cockpit was lined with this stuff
Berkie is offline Find More Posts by Berkie
Discussion Polymorph protects your Foamie Berkie Foamies (Kits) 3 Mar 19, 2014 08:58 PM
Discussion Nitikin-Shevchenko IS-1(I-220) Polymorphic Fighter for Scratch Build Off 3 CryHavoc Scale Kit/Scratch Built 26 Sep 10, 2008 08:23 AM
Discussion Anyone ever used Polymorph CrashingDutchman The Builders Workshop 2 Sep 02, 2006 02:05 PM
Discussion Polymorph - handy stuff? Roger Lombard GWS (Grand Wing Servo) 6 Jun 21, 2006 10:39 AM
Yippee! i found this on ebay polymorph swheels Motorcycles 6 Apr 29, 2005 07:35 PM
