Old Yesterday, 09:24 AM
United Kingdom, Kirkby Fleetham
Joined Jul 2014
Question
testing failsafe/Return to home Phantom FC40
Has anybody any advice for testing the failsafe feature on FC40, I'm reluctant to try without knowing the consequences!
stuk34 is offline Find More Posts by stuk34
Old Yesterday, 09:39 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Make sure you are in open area.
Make sure you have good GPS signal.
Fly away not too far but far enough
If lower then X amount of altitude the model will climb to X amount of altitude so be prepared to see it climb before turning around and heading home.
While the model is heading back home put the transmitter into Attitude Mode so that if you need or want to abort you can quickly regain control of the model. If you leave the Tx in GPS Mode you will NOT regain control of the model.
freechip is online now Find More Posts by freechip
Discussion Tested FC40 Home Function random155 Multirotor Talk 2 Jul 18, 2014 08:55 AM
Discussion Failsafe: Return to Home - Ever have to depend on it? MikeMSD Multirotor Talk 20 Feb 03, 2014 04:35 PM
Question Return to Home,failsafe EugeneFlorida Eagle Tree Systems 6 Nov 16, 2010 10:31 AM
Discussion Quadrocopter with GPS hold and return home when failsafe ??? TTcuatro Coaxial Helicopters 2 Sep 11, 2009 05:31 AM
