Old Jul 24, 2014, 04:29 AM
Bangkok
Joined Jul 2003
Help!
Silicone hinge need advice
I have balsa fully sheeted wings and want to do a silicone hinge.
Should I silicone onthem before covering with monocote or after covering?
Piyarost
Piyarost is offline Find More Posts by Piyarost
Old Jul 24, 2014, 05:26 AM
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Piyarost
after for me
Kenny Sharp is online now Find More Posts by Kenny Sharp
Old Jul 24, 2014, 06:25 AM
R.M. Gellart's Avatar
Joined Nov 2005
Silicone works great on molded and bagged ships, but I would recommend 3M clear plastic tape if you are using monokote.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Jul 24, 2014, 06:39 AM
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Marc
Scotch 3M 600 that I get at the big box stores.
Curtis Suter is online now Find More Posts by Curtis Suter
Old Jul 24, 2014, 07:51 AM
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
If you silicone after covering, the hinge strength will rely totally on how well the film remains stuck to the frame. I therefore apply silicone to the frame before covering.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Jul 24, 2014, 01:45 PM
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
I use Goop/Shoo Goo/PFM type glues, but same technique.
I have gliders...some fast, some slow. I don't have any giant/heavy power planes. The glue sticks fine to Monokote. During crashes/mid-airs, I've had the glue separate from the Monokote, but only with lots of other damage. During flight loads, I've not had a failure. I've gone as narrow as an 1/8" width of glue on each side (for total width of 1/4") to see how small I can get away with (it's pretty small).
The advantage is that it won't loosen up like tape. Tape is messy as it ages poorly, and can be hard to clean up...did I mention they loosen up and need lots of re-application?
If I had a large scale, heavy, fast plane, I might use the glue right to the wood and cover it after...
cityevader is online now Find More Posts by cityevader
Old Jul 24, 2014, 04:49 PM
Joined Nov 2005
This is what I am talking about, the above tape is cellophane. This tape has great tack, can b removed, and does not get brittle like mylar. I get it at Ace Hardware around here, there are colors too, but clear is the best.
Marc
Old Jul 24, 2014, 04:56 PM
cityevader's Avatar
Joined Mar 2012
That IS great (the best?) tape, for sure...but i still like "silicone hinges" better
Help! What's the best Silicone to use for damaged Kevlar hinges kbstingwing Slope 16 Jan 31, 2014 10:16 AM
Question Need advice: aileron hinges Amko The Builders Workshop 2 Apr 25, 2010 11:22 AM
Discussion Hinging advice needed davidjensen Slope 13 Mar 20, 2008 06:11 PM
Discussion hinge tape/ need advice skipinhouston Sailplane Talk 15 Jul 04, 2006 01:51 PM
Glueing techniques for nylon hinges - need advice Yokozuna The Builders Workshop 9 Dec 15, 2004 05:26 AM
