Old Apr 27, 2014, 08:13 AM
United States, MA, Lowell
Joined Dec 2008
At this rate you should have it ready for N.Carolina .
Homeport is offline Find More Posts by Homeport
Old Apr 28, 2014, 12:20 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
getting ready for the Oct. fleet gathering just got a little closer, molds were just successfully separated from the masters, they look very good, should just need a good scrubbing and it will be time for wax and PVA followed by resin and glass.. (might have a hull by the weekend) the masters also survived fairly well (much better than the brooklyn's, I think I learned a bit on that project)
tghsmith is online now Find More Posts by tghsmith
Old May 01, 2014, 07:12 AM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
molds have been trimmed, filled, edge taped, waxed and pva'd, clothe is cut after a pattern was made.. http://thayercraft.com/ have to give these guy's a +1 have used them before, got a roll of 3.7 oz surfboard glass, very fine weave and is so soft it just drops into the mold(nice stuff) may have a hull together by monday aft.. ....
Old May 01, 2014, 01:54 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
the new glass laid so well both halfs were done today... then its trim the edges and join the halfs...
Old May 02, 2014, 07:05 AM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
trimmed the molded edges and with very little effort out from the molds they came.. will let them sit in the sun a bit give them a good scrub down some light sanding at the seems and bilge base... then the two become one!!!
Old May 05, 2014, 02:31 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
half hulls joined, a little more trimming on the top edges done via belt sander(need some full sheets of sandpaper to make a some large blocks to get good final edges) put her on the scale and added water to the water line.. right around 9lbs of displacement. things ordered to build the running gear..
Old May 05, 2014, 05:20 PM
Tug Hercules Fireman
Tug Hercules's Avatar
Canada, AB, Medicine Hat
Joined Mar 2008
Excellent !!
The model in the background with the three stacks; What colour/color of brown/tan is that on the stacks and deck cabin? And by which manufacturer?
Thank You.
Tug Hercules
Fireman Rick
Tug Hercules is offline Find More Posts by Tug Hercules
Old May 05, 2014, 05:24 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
http://www.rcgroups.com/forums/showt...light=brooklyn
Old May 05, 2014, 07:41 PM
Vince Hoffmann's Avatar
Hayward, CA
Joined Jan 2009
Beautiful !! How much are you selling the hulls for?
Vince Hoffmann is offline Find More Posts by Vince Hoffmann
Old May 05, 2014, 08:37 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
if I sell any that will be down the road a bit, have to make sure it all works out, this ship has some complications . outboard angled shafts, tight rudder area, lowered exposed central gun/boat deck.. plus reworking a set of plans (research on this one has been tough)
Old May 05, 2014, 09:05 PM
Joined Dec 2008
Are the A frames the same as on the Arizona ?
Are you planning on using those pitman motors in this build?
Looking great.
Old May 06, 2014, 05:31 AM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
the shaft frames are like the brooklyn's but the shafts are not parrallel to each other, I have some 12volt pitt's that should give better than scale speed (22kts) fit well, good low speed power with direct drive so the drive train will nice and quiet..
Old May 12, 2014, 08:11 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
a sheet of fiberglass was cut for the main subdeck, epoxied glassed into place, after some curing time the access cut-outs will be roto-zipped , other ordered materials have been showing up..
Old May 21, 2014, 07:54 PM
tghsmith's Avatar
Raleigh NC
Joined Jul 2008
filled, sanded and primed . deck lines have been trimmed its time to get the machine shop working on the running gear..
Old May 21, 2014, 10:20 PM
Joined Dec 2008
It`s coming together.
For Sale Multiplex MiniMag RTF - LPU Raleigh, NC area cshepherd Aircraft - Electric - Airplanes (FS/W) 3 Feb 03, 2014 01:54 PM
For Sale Relisting for my Glider can be seen in person at Raleigh Hobby in Raleigh NC WallsRoofing71 Aircraft - Sailplanes (FS/W) 0 Jan 30, 2011 06:36 PM
Mini-Review C.C. Lee 1/400 USS Enterprise (CVN-65) Plastic Kit In-box Review...A kit for RC fun? Kronosaur Scale Boats 1 Sep 12, 2009 08:22 AM
Raleigh N.C. nightflying strat919 3D Flying 7 Aug 05, 2005 05:40 PM
RAMS 3rd annual electric funfly 2 day even in Raleigh, NC August 7 + 8 Steve H. Electric Flight Events 76 Aug 17, 2004 11:41 PM
