Old Jul 15, 2015, 05:42 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
It also helps to glass the upper surface, very easy and minimal weight gain .
420flyboy is offline Find More Posts by 420flyboy
Old Jul 21, 2015, 08:32 PM
Squinton is online now
Find More Posts by Squinton
Joined Mar 2014
Hey all,
Quick question: Quality of build, foam, servos and retracts compared to a similar priced Freewing or Lanxiang (skyflight hobby) edf foamies?
Much appreciated!
Squinton is online now Find More Posts by Squinton
Old Jul 22, 2015, 02:32 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Anyone need any of these wheels brakes.. let me know.
http://www.rcgroups.com/forums/showthread.php?t=2276790
viperviper is offline Find More Posts by viperviper
Old Jul 22, 2015, 05:50 AM
CletusB is online now
Find More Posts by CletusB
CletusB's Avatar
Trinidad & Tobago
Joined Sep 2011
Originally Posted by Squinton View Post
Hey all,
Much appreciated!
IMHO I love it. No issues with mine. been flying it every weekend.
CletusB is online now Find More Posts by CletusB
Old Jul 22, 2015, 04:39 PM
Joined Mar 2014
Thanks!
Old Jul 23, 2015, 09:45 AM
mhendrix is online now
Find More Posts by mhendrix
In thrust we trust.
mhendrix's Avatar
United States, FL, Tallahassee
Joined Jun 2013
Originally Posted by Daniel F EDF View Post
+1
I have wemo midi evo. It is a better performer but the sound is much worse...
Do you have the 11 blade?
I have the wemo evo 11 blade, and a het typhoon motor. I had to do some extra balancing with the spinner to make it silky smooth. In the air it's silent unless you are doing a pull on throttle. Sounds like the real thing! 115mph 8S 5000 40C
I ended up fitting the het and emo fan to the stock taft fan shroud because of some issues when I transferred the 8S setup from my first viper (foam hinge failure....). There is a little gap between the fan blades and the housing which only affects out of the hole power. Makes for longer take offs on grass but no issues otherwise
mhendrix is online now Find More Posts by mhendrix
Old Jul 23, 2015, 04:42 PM
HellHathNoFury is offline
Find More Posts by HellHathNoFury
Joined Dec 2013
If you fit Wemo Evo into a Het 9305 housing it fits perfectly in it .. That's what is used in most Wemo setups... The new housing is extra solid not like the Taft one which is wafer thin & easily breakable..
HellHathNoFury is offline Find More Posts by HellHathNoFury
Old Jul 23, 2015, 06:56 PM
In thrust we trust.
mhendrix's Avatar
Joined Jun 2013
How does the inlet fit in the groove in thr viper fuse?
Old Jul 23, 2015, 09:42 PM
Joined Dec 2013
You can do it two ways..
1) Dremel off back part of Het lip to form a lip
2) Cut a bit off the Taft Lip ( small bit at a time ) to lessen the diameter of it so it can fit diameter of Het shroud ... Once it fits just epoxy the two joints together ( I used fibreglass cloth as well to bond/strengthen joint. Once dried you can just tape it to the front shroud as per my pics... A bit of improvisation..
Old Jul 23, 2015, 10:32 PM
In thrust we trust.
mhendrix's Avatar
Joined Jun 2013
2) Cut a bit off the Taft Shroud ( small bit at a time ) to lessen the diameter of it so it can fit diameter of Het shroud ... Once it fits just epoxy the two joints together ( I used fibreglass cloth as well to bond/strengthen joint. Once dried you can just tape it to the front shroud as per my pics... A bit of improvisation..
So if I understand correctly, you retro-fitted the inlet lip of the Taft shroud to fit the het shroud? Seems easy enough! I think I will benefit from having the fan blades closer to the edge of the inside of the shroud. Only $20 on effluxrc. Thank you!
Old Jul 23, 2015, 10:44 PM
Joined Dec 2013
Yep.. Just retrofitted the Taft lip... Easy peeasy ..
Discussion New 90mm Viper Jet Chris True Electric Ducted Fan Jet Talk 20 Nov 18, 2014 12:33 PM
Build Log FOAM Viper Jet MK2 with 90mm 12 blade EDF (made by Ysnk) ysnk Scratchbuilt EDFs 16 Sep 25, 2012 02:40 PM
Discussion Viper jet 90mm from hk balone10 Electric Ducted Fan Jet Talk 2 Mar 09, 2012 05:57 PM
