Old Nov 06, 2014, 04:06 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
Hotliner FPV'ing? anyone do it yet?
Has anyone FPV HotLiners?
I would do this one in the open desert if I could afford it
TURN VOLUME way UP!!!!
Hurricane Elektro mit 8S (3 min 32 sec)
rclab1 is offline Find More Posts by rclab1
Old Nov 06, 2014, 05:56 PM
Dogdude is offline
Find More Posts by Dogdude
Joined Aug 2012
Hotliners are awesome
I have just finished setting up an old school one with the intention of FPV'ing it
Not sure mine is fast enough though, it's a Simprop Lift-Off original (1935mm)
Aveox FL10 motor running on 3S with a 17 x 13 prop 1100 watts and around 100 amps
It's fast but not special fast
Dogdude is offline Find More Posts by Dogdude
Old Nov 09, 2014, 05:58 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
http://www.youtube.com/watch?v=KyFVpuy2sYY
Oh ya baby
Done three hot liners with countless hours and miles under my belt
F5b hotliners work very well
I started experimenting with hotliners back in 2009ish
Foam was just too slow
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Nov 13, 2014, 12:27 AM
fluxcapacitor121 is offline
Find More Posts by fluxcapacitor121
The Future is Gnar
fluxcapacitor121's Avatar
Joined Dec 2011
Very cool.
The sounds that bird makes are killer.
fluxcapacitor121 is offline Find More Posts by fluxcapacitor121
Latest blog entry: The Story Behind My Avatar
Old Nov 13, 2014, 02:02 AM
DX188 is offline
Find More Posts by DX188
RC TERMINATOR
DX188's Avatar
Joined Oct 2014
Cool. How much does the aircraft weigh?
DX188 is offline Find More Posts by DX188
Old Nov 13, 2014, 12:44 PM
parajared is offline
Find More Posts by parajared
no guts no glory
parajared's Avatar
United States, AZ, Prescott
Joined Oct 2013
I presume they aren't done as much as other platforms because you would be either looking through the prop or have a camera out on the wing.
Would a hotliner outperform your standard funjet/skyfun/stryker setup in any way?
parajared is offline Find More Posts by parajared
Old Nov 13, 2014, 05:17 PM
Dogdude is offline
Joined Aug 2012
Yes
Cut the throttle and it keeps going at nearly full speed for what seems like an eternity
The sound they make on zero power as they cut through the air is awesome, they won't suffer anywhere near the same torque roll problems
They can be made to go much faster than foamies and for longer duration
Old Nov 13, 2014, 05:51 PM
no guts no glory
parajared's Avatar
Joined Oct 2013
I thought Jag's post about how the Australian pylon team was using cheap hobbyking hotliners to practice for F5D tournaments would be worth sharing here too.
Sounds like they are ripping around at a bit under 200mph for $300
Maybe the same setup could be put on one of the mondo cheapo flyfly hotliners like the GL Speedy. 200mph for $200?
http://www.rcgroups.com/forums/showp...4&postcount=45
Old Dec 05, 2014, 05:22 PM
no guts no glory
parajared's Avatar
Joined Oct 2013
pusher hotliner?
What about buying a hotliner wing (wing only) and configuring it like a skyhunter or xuav talon? Wad all your battery and electronics into a tiny homemade fuse.
Old May 17, 2015, 03:32 PM
no guts no glory
parajared's Avatar
Joined Oct 2013
I'm considering using a Durafly EFX wing (only $20) and pairing it to a homemade fuse built to be a pusher.
What do you guys think?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Old May 19, 2015, 04:13 PM
Dogdude is offline
Joined Aug 2012
Cool idea
Been thinking about doing the same with one of my spare sets of pylon wings (got a HK Shark and an Arrow)
Old Jun 04, 2015, 12:25 PM
no guts no glory
parajared's Avatar
Joined Oct 2013
My pusher hotliner idea is starting to take a turn for the crazy! Now I am shooting to have the weight of the motor below the wing and a driveshaft from the motor out to the back of the tail. The plane flies so awesome in my imagination itís hard to believe anything could go wrong in real life.
Discussion Blade 350 QX: Anyone install FPV pack yet? olflyguy Multirotor Talk 1 Nov 13, 2014 06:01 PM
Discussion FPV planes or miniQuad FPV'ing? What do you guys prefer? rclab1 FPV Talk 7 May 14, 2014 07:22 PM
Discussion Has anyone tried one of these FPV planes from HK yet? randall1959 FPV Aircraft 1 Mar 25, 2011 07:17 PM
Discussion FPV'ing at night - do's and dont's ? chancesAU FPV Talk 12 Jun 26, 2010 02:36 PM
Anyone do AMI Huckbein yet? monkamarm2000 Electric Ducted Fan Jet Talk 3 Jan 15, 2003 04:01 AM
