Old Mar 27, 2015, 12:23 AM
furballll is offline
Find More Posts by furballll
lost in the addiction of flyin
furballll's Avatar
Canada, BC, Kelowna
Joined Dec 2009
Originally Posted by modelerchina View Post
without having to go through 400+ pages, can someone show me how the motor is mounted, they only have two wood stick, and manual suggest to screw motor mount to the stick.
Not knowing what motors your running yet or how they are to be mounted all I can say is what I did on mine.
I took a hole saw the same size as the center of the nacelle and made myself a mounting plate and attached the motors to a flat piece and did not use the stick style mounting.
what others have done and I like the idea more, and if I had to do it again this is how I would do it. Cut the end off the nacelle off and and fashion a firewall to it then use the piece you cut off as a cowling. Its much cleaner of a job and super easy to do, plus you can then run spinners that sit nice and tight.
furballll is offline Find More Posts by furballll
Old Mar 27, 2015, 02:36 AM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
I did the same as Griphin .. calculate how far back the firewall would need to be so the motor doesnt protrude out much (or what you consider it should).. cut the nacelle front part.. hollow the front end ... glue firewall to the back.. screw the motor in and install wires and then i just use 3 drops of hot glue to hold the front couling in place
I also cutted down the motor shaft so the spinner would be right close to the motor.. therwise its quite far
end result:
JLT_GTI is offline Find More Posts by JLT_GTI
Old Mar 30, 2015, 04:59 AM
lthibault is offline
Find More Posts by lthibault
Luc
lthibault's Avatar
Joined Dec 2004
In my case I discarded the sticks, used round plywood pieces epoxyed in the motor areas.
lthibault is offline Find More Posts by lthibault
Old May 24, 2015, 11:43 AM
JCN52 is offline
Find More Posts by JCN52
Malaysia, Perak, Ipoh
Joined Sep 2008
The manual I have does not have any sugested control throws can anyone advise please.
JCN52 is offline Find More Posts by JCN52
Old May 24, 2015, 03:06 PM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
@ JLT_GTI
Which spinners are those?? Do you have a link?
PS nice job!
idletime is offline Find More Posts by idletime
Old May 24, 2015, 04:37 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
I just maxed them all.. max possible throws without having the servos "protest" .. it goes nice and flies very scale.. i have done rolls and loops with it but its a plane that doesnt ask for those anyway
Originally Posted by idletime View Post
@ JLT_GTI
PS nice job!
They are the 3-blade prop spinners that came with my kit...
the kit actually had 3 blade 8X4X3 props (they are still arround in some box) .. but i bought a set of MasterAirScrews 8X6X3 and use the collet adaptor that came with the motors (2830 1100Kv) with the spinner and so far worked perfectly
As far as i seen there are several diferent kits out there even with the same "yellow" Scooper .. i seen kits with 2 blade props, 3 bladed props.. 2 and 3 bladed spinners and some with aparent no spinners at all
Old May 29, 2015, 05:27 AM
G.Roman is offline
Find More Posts by G.Roman
Joined May 2015
GoPro HERO3: FPV Canadair CL-415 Malaysia HobbyKing (4 min 44 sec)
G.Roman is offline Find More Posts by G.Roman
For Sale MR Aerodesign Canadair CL-415 Kit Complete Rudderman98 Aircraft - Fuel - Airplanes (FS/W) 0 May 09, 2009 07:05 PM
Found Canadair CL 415 kit,ARF, ARC,or plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 2 Nov 13, 2008 05:41 PM
Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans rcdude01 Aircraft - Electric - Airplanes (FS/W) 1 Oct 17, 2008 04:54 PM
For Sale Canadair CL-415 Kit NIB EAMRC Aircraft - Electric - Airplanes (FS/W) 1 Oct 29, 2006 11:36 AM
FS: Canadair CL-415 Kit Rudderman98 Aircraft - Electric - Airplanes (FS/W) 3 Oct 11, 2004 09:54 PM
