Old Nov 03, 2015, 06:33 PM
giantpt is offline
Find More Posts by giantpt
Portugal, Faro District, Tavira
Joined May 2013
Alert
Convert kite to paramotor
Hi guys,
Is there a formula to convert the lines of a kite into a paraglider/paramotor?
I have everything with me like a 3m2 kite, motors, props, radios, servos, bats and even a cnc router to produce any needed parts but I can't find any information on how to make this convertion.
Thank you
Regards
giantpt is offline Find More Posts by giantpt
Old Nov 04, 2015, 09:37 AM
Chrizz is offline
Find More Posts by Chrizz
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
Hi!
The most critical part of a good conversion is, to make a new line-set.
You should spend some time finding different threads/blogs of people making paragliders (either some kind of rs-scale or full-size; rcgroups.com, parapenterc.com, paragliderforum.com e.c.t. ...) and get inspired.
Also take a look at Surfplan, a program allowing you to design line-sets.
Good luck
Happy landings :-)
Chrizz is offline Find More Posts by Chrizz
Old Dec 16, 2015, 03:55 AM
fotoreb is offline
Find More Posts by fotoreb
Paul Rebnord
Joined Mar 2015
build paramotor
Hi
im looking around to find som scetches of a paramotor trike...
i am a kitesurfer so i have this smal training kite laying around. so i will try to make a paramotor..
It rather big. its a 4m2 kite.
i have a a nice low kv motor ( 360kv )
that draws 30A on 6s. with a 16". prop
if anyone has any drawing sketches or other build logs to show me i would be greatfull.
How big throws do my servos need and what torqe?
how many whatt's of power is needed for every m2,
how light or heavy should it be?
how long lines?
Any advice is apritiated.
Thanx
fotoreb is offline Find More Posts by fotoreb
Old Dec 16, 2015, 05:01 AM
fotoreb is offline
Paul Rebnord
Joined Mar 2015
the kite
The kite i will use
Old Dec 17, 2015, 05:49 PM
fotoreb is offline
Paul Rebnord
Joined Mar 2015
my build
Originally Posted by fotoreb View Post
The kite i will use
http://www.rcgroups.com/forums/member.php?u=588335
Old Dec 18, 2015, 09:13 AM
Aeronut41 is offline
Find More Posts by Aeronut41
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Good luck! Hope you get it flying. Maybe a more reasonable cost simple option for para-sailing Aero
Aeronut41 is offline Find More Posts by Aeronut41
Old Jan 01, 2016, 05:09 PM
jwellsy is online now
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
Have you found any more info on using a power kite as a powered parachute?
I have a 4 line 5.6 sm kite and 2 HobbyKing 94" 1/3 scale ultralights. I'm thinking of building one with a tail and wing and using the gondola from the other one with the kite for a powered parachute.
With my kite already having 4 lines I don't think I need to modify it much, maybe line lengths but that's about it. The front power lines I'll mount static and put the 2 rear brake lines on servos.
jwellsy is online now Find More Posts by jwellsy
Old Jan 02, 2016, 12:41 PM
Joined Aug 2012
I flew my 5.6 sm Peter Lynch kite today for it's maiden. It was pretty impressive how strong it is, and it's visual wow factor. The wind was 10 mph and I had a buddy hold the canopy down while I straightened the lines. A couple of times it pulled me along and a couple of times I had to just let go of it the pull was so strong. I flew it several short flights, each one having more control than the previous.
I definitely need 4 shorter control lines for a powered parachute.
Old Jan 07, 2016, 04:49 AM
NunoFlyer is offline
Find More Posts by NunoFlyer
NewBie - Always crash
NunoFlyer's Avatar
Portugal, Aveiro
Joined Aug 2010
Originally Posted by giantpt View Post
Hi guys,
Thank you
Regards
Hi,
Itīs a problem, because the kites dont ready to fly.
I test with one small kite but unsuccessfully.
Regards
NunoFlyer is offline Find More Posts by NunoFlyer
Idea Make an RC Kite out of a 2 line Stunt Kite jegouvrc RC Paragliders and Kites 2 Oct 25, 2015 05:37 PM
Off Site Squadron Kites Curtiss 'Jenny' JN-4D, 60" span airplane kite, New In Box! sdrob15 Aircraft - Electric - Airplanes (FS/W) 0 Oct 15, 2015 12:39 AM
Off Site Squadron Kite / Coast Kites 1/9 Scale Spirit of St. Louis NEW kit, unique model! sdrob15 Non R/C Items (FS/W) 0 Sep 19, 2015 12:36 PM
New Product X1-A v.4 Paramotor Trike - BMR PARAMOTOR R/C BMR PARAMOTOR RC RC Paragliders and Kites 1 Jul 10, 2015 12:43 AM
Discussion Anyone use a Qunlon power kite for an RC Paramotor Charlescd RC Paragliders and Kites 1 Dec 03, 2014 02:56 PM
