Old May 02, 2014, 05:14 PM
SpadCat2000 is online now
Find More Posts by SpadCat2000
United States, AZ, Lake Havasu City
Joined Feb 2010
Question
Easier Sanding?
Picked up a vintage Katie II sailplane and am now sanding the foam/balsa wing. Forgot how much work sanding this much surface is.
I guess my question is, are any of you balsa builders/finishers using any sort of electrical sander to make this task easier. Anything new on the market?
SpadCat
SpadCat2000 is online now Find More Posts by SpadCat2000
Old May 04, 2014, 10:24 PM
gzkpez is offline
Find More Posts by gzkpez
Joined Jan 2006
Newer Better sandpaper, with a sanding block and the right grade. Balsa really benefits high grade sandpaper. Seems to like the extra sharp grit. I tanged some of that Portuguese paper on a order just to try and was astonish how well it worked on balsa.
I have been disappointed when trying electric sanders in the past. But maybe some one had good luck with one.
gzkpez is offline Find More Posts by gzkpez
Old May 05, 2014, 03:09 PM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Straight Line Air Sander
Naturally one would need a compressor with an adequate duty cycle
Jared
jcstalls is offline Find More Posts by jcstalls
Old May 05, 2014, 04:57 PM
Joined Feb 2010
I don't skimp on sand paper either, and have a number of good sanding blocks. I also have been disappointed in electric sanders that I have used in the past. "Portuguese paper"? Any links to sources? I will Google it. Thanks.
"Straight line Sander"? I used to have a combo orbital/straight sander, but it just seemed to be as much work as a sanding block. It might just needed to have more movement than the vibration motion that it had and a belt sander has too much movement.
Maybe I am just getting lazy in my old age....
SpadCat
Old May 05, 2014, 06:11 PM
jcstalls is offline
jcstalls's Avatar
Joined May 2002
Perhaps the older manual straight line Sander.
Oh, I don't know about getting lazy in me old age, more like conserving energy, especially my own.
Jared
Old May 06, 2014, 07:30 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Jared
I believe they are called "sanding files." I have two, so that I can easily switch grits without wasting paper. They are still available at automotive paint stores.
TomCrump is offline Find More Posts by TomCrump
Old May 06, 2014, 08:57 AM
jcstalls is offline
jcstalls's Avatar
Joined May 2002
Yup, that's the one. Forgot name for it's been years since I bought mine.
Old May 06, 2014, 12:40 PM
Joined Feb 2010
OK, I will try one.
Old May 06, 2014, 01:59 PM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
I love Mirka Abranet products. The geometry of a thin thread contacting the surface to be sanded makes them cut extremely well and since it is an open mesh, it doesn't clog up. A possibility to use a vacuum cleaner to suck dust through the sanding pad is a bonus.
jkettu is offline Find More Posts by jkettu
Old May 06, 2014, 02:57 PM
jcstalls is offline
jcstalls's Avatar
Joined May 2002
Another trick with these is to load up a few sheets, when sanding a lot. This way one just rips off the used sheet verses replacing it every time.
Also, a quality unit is usually better than a budget one. Beside Trueness, the ease of replacing sheets.
Jared
Old May 07, 2014, 10:26 PM
Joined Feb 2010
Hmmm..interesting. So you use the sheets on a electric finishing sander or attach them to a sanding block?
Old May 09, 2014, 08:56 PM
gzkpez is offline
Joined Jan 2006
The brand name I use Indasa Rhynalox Plus. I got some sheets of generic paper from a woodwork shop that was closing and it was just labeled "Portuguese Paper" and a grit number. Later I noticed that the other paper I liked was made in Portugal, by www.indasa.pt . For me, now that my arm hurts and am building larger planes, it seems that the better paper is the difference between enjoying or dreading sanding. It does not pack up and need much less effort to sand due to sharper grit. The downside it makes a lot more dust .
That Mirka Abranet paper looks interesting, if I can find a small inline sand for it I will give it a try.
SpadCat
Old Nov 20, 2014, 12:18 AM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
I'm astonished that you have a problem sanding balsa?
The few times that I have done it, it disappears very quickly. So much so, there is a danger of over sanding. Also, I use a plane first to take off any excess in true joinery fashion. Then sand only to finish up.
I'm currently sanding 2 pack auto paint finished plugs. If you want a hard sanding experience, try this one day.
The balsa will seem like childs play after that!
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Nov 20, 2014, 09:32 AM
049flyer is offline
Find More Posts by 049flyer
United States, TX, Tyler
Joined Sep 2009
My solution is to build smaller planes!
049flyer is offline Find More Posts by 049flyer
Old Nov 23, 2014, 12:41 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
I find that sanding screens, used for sanding drywall joints, gives a great finish without clogging. The 3M brand can be found at most big box home improvement stores in the paint department. A wider selection of grits is available from auto body paint stores.
FoamCrusher is offline Find More Posts by FoamCrusher
Question Is it Easier To Fly FPV vs Traditional ? FlyHighSelllow FPV Talk 20 Apr 02, 2014 10:27 AM
Discussion How much easier could they make it? JCMorgan Trader Talk 14 Mar 30, 2014 04:38 PM
Mini-HowTo Prevent damage and make batteries easier to remove on v252 and Hubsan X4 series quads ajg23 Mini Multirotors 1 Dec 23, 2013 07:15 AM
Idea Add LEDs to cheap ebay LCD backlights for easier viewing in sun??? rudyauction509 FPV Equipment 0 Dec 08, 2013 01:48 AM
