Apr 01, 2011, 05:25 AM
Australia, ACT, Kambah
Joined Feb 2001
Originally Posted by Grunta5
Hi Dereck, its built off the original plan. I just moved the firewall forward to compensate for the shorter motor.
Ive built about four Kadet juniors now, I did electrify one about 12 years ago and put a 540 canned motor and a 9.6v nicad pack in it... it flew but not that well, it did give me a taste for electric tho... :-)
I used the servo/ switch method too, very proportional.. on and off!!
I might build an aileron wing for it next , I cant believe im getting almost 30 minutes cruising around on the 2200 lipo .
Id be interested to know what the model was you mentioned
I think the Kadet junior would be good scaled up to around 63 inches , (same construction , sheeted sides not stick) , it wouldnt be a junior then though would it....
Grant.
... no it wouldn't, but it could be a Sig Kadet LT-25, a 63" taildragger with sheet sides and ailerons, and it would weigh about 2kg and fly darned well on as little as 240W, and be tough enough to survive being flown into a dirty great gum tree because some clown forgot he actually needs his specs to see an acft beyond 50m away these days. Maybe this weekend I won't bend the gear before I find out how it flys on 450W. As Dereck says, you'd reasonably suspect it was designed to be electric from the outset, and it's a beautiful quick laser cut build.
