Old Jul 13, 2014, 10:16 PM
United States, TX, Houston
Joined May 2003
How to glue canopy to fuse
Has anybody posted a 'how to' for glueing a clear plastic canopy to a fuse ? For example, how do you glue a canopy for a Kwik Fli to the fuse without getting glue everywhere and so there is a seamless transition from the canopy to the fuse?
Hoot is offline Find More Posts by Hoot
Old Jul 13, 2014, 10:51 PM
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
We use canopy cement. dries clear and cleans up with water, then add a trim strip of covering.
Before and after:
http://www3.towerhobbies.com/cgi-bin...&I=LXCX70&P=ML
We use it to glue in servos in the foam planes.
On some we use silk pins to look like rivets.
Kimber is online now Find More Posts by Kimber
Old Jul 13, 2014, 11:02 PM
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
mmmmmmmmmmmmmmmmmm
Old Jul 14, 2014, 12:41 PM
David
dmarusa's Avatar
Joined Mar 2012
I have been using E6000 for quite some time now with good luck. Originally, I was applying it wet and letting the canopy cure in place. Lately, I have been applying it to both surfaces and joining them like a triditional rubber cement. Until it is fully cured, any excess can be rolled off with your fingers after it gets tacky. I haven't had any issues with fuel, but I'm not positive that it is fuel proof.
dmarusa is online now Find More Posts by dmarusa
Old Jul 15, 2014, 05:37 PM
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
E6000 is absolutely remarkable. 19 years ago, my (then new) wife and I bought our first home. We didn't like the cheap house numbers the builder put on, so I got a nice power coated frame and ceramic tile numbers at Home Depot. Only problem....how to fasten them to the stucco exterior? Hey, how about E6000! So, I got a tube, glued the tiles into the frame, and glued the frame to the stucco. We are long since gone from that house, but last summer we drove by, and it's still there. And this is in Las Vegas, where it's about a billion degrees in the summer, and can dip below freezing in the winter.
Sorry to drift way off topic here, but if anyone has any doubts as to E6000's holding power, well, there you go.
LVsoaring is offline Find More Posts by LVsoaring
Old Jul 15, 2014, 06:00 PM
builderdude's Avatar
United States, TX
Joined Jun 2011
Nice job, Kimber. Very nice.
builderdude is online now Find More Posts by builderdude
Old Jul 15, 2014, 08:00 PM
Joined May 2003
Thanks for the photos but I am looking for a seamless transition from the fuse to the canopy.
Old Jul 15, 2014, 08:38 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Not much but look at post # 23 http://www.rcuniverse.com/forum/cras...l#post11038682
Ken
kenh3497 is online now Find More Posts by kenh3497
Discussion Pacer Poly-Zap as canopy glue jpurcha Balsa Builders 1 Dec 31, 2013 04:59 PM
Question How well do non drip glue guns work? RC Aerobat The Builders Workshop 1 Oct 15, 2013 01:00 PM
Help! How to make a fuse with a flush fitting canopy? soholingo Composites Fabrication 10 Jun 24, 2010 09:23 AM
Discussion How to carbon sleeve a sloper soarer fuse with a canopy? mr_editor Composites Fabrication 3 Nov 08, 2009 03:21 PM
Discussion Super Scooter-How to glue wing to fuse? dst Slope 17 Sep 03, 2006 05:36 PM
