Old Aug 12, 2006, 08:04 PM
Joined Aug 2006
Charger / Balancer recommendations
Would I be wrong to expect to be able to charge my 3s 2100 packs at 6A if I were using the LBA10 and an Astro 109 charger? The charge leads on the LBA 10 appear to be a little on the small side to charge at this high of a rate.
These are the biggest packs I have. It looks like I can get the charge rate I want with this combo, or am I just better off spending the extra money and getting the TP charger and balancer?
pmona is offline Find More Posts by pmona
Old Aug 12, 2006, 09:20 PM
Sydney, Oz.
Joined Mar 2006
That combination will work fine at 6A. Be aware of the possible reduction in cell life if you charge at 6A.
HPSOV is offline Find More Posts by HPSOV
Old Aug 13, 2006, 02:15 AM
WWW.RITEHOBBY.COM
ildo's Avatar
Sunnyvale, CA
I would suggest you to save your money if you can wait for a couple of months.
we will have a new charger take care your needs.
Jun
ildo is offline Find More Posts by ildo
Old Aug 13, 2006, 09:59 AM
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
YES, a balancing charger capable of 12 amps for each cell for 4400 mah packs
hall woo is offline Find More Posts by hall woo
Old Aug 13, 2006, 10:05 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
hall , are you going to use 20 ga. super flex wire and Deans Ultras or Sermos/APP connectors for the taps?
Show me a factory / vendor supplied LiPoly tap that can stand a 12A charge through it. I have had some to over heat at 2A.
Charles.
everydayflyer is online now Find More Posts by everydayflyer
Old Aug 13, 2006, 10:18 AM
Permanently Banned
Joined May 2003
how about a compact standard female multi-pin dc connector onboard the 4400 mah packs, many to choose from
Old Aug 13, 2006, 10:30 AM
Southern Pride
And you are going to convince all of the LiPoly vendors to use the same connector,right?
Charles
Old Aug 13, 2006, 04:48 PM
Permanently Banned
Joined May 2003
NO, again they will use their own special dc power connector and again we have to worry about adaptors for the balancers again
Old Aug 14, 2006, 01:55 PM
Joined Aug 2006
I'm not sure where this thread went with the ...12 amps for each cell for 4400 mah packs....
So what is the consensus? Am I good going with the Astro 109 and the LBA10 to charge my TP 3S 2100 packs at 6A (3C)? or do I need to spend the extra money and go with the TP charger an balancer? The TP set up is what I have seen a few of the guys at the field use, but I would prefer to save $100 if I can and get another battery.
Discussion Charger and battery balancer recommendations for the Lama Paul6ppca Coaxial Helicopters 0 Jan 02, 2007 08:57 AM
New Product New Charger/Balancer Coming Soon 2dogrc Batteries and Chargers 11 Jan 09, 2006 07:03 PM
Which Charger/Balancer setup? EricJ320 Batteries and Chargers 2 Dec 13, 2005 12:42 AM
Charger-balancer in one?? Hard Wiggles Batteries and Chargers 6 Oct 05, 2005 06:01 PM
More info on Thunder Power Charger/Balancer? Brill 1 Batteries and Chargers 2 Feb 05, 2005 06:21 PM
