Old Jun 28, 2015, 06:46 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
New Product
Twisted Hobbys - 43in EPP Crack Turbo Big Beaver - aka Big Beaver
INTRODUCTION
Introducing the 43" EPP Crack Turbo Beaver, AKA The Big Beaver! The BIG Beaver represents the ultimate in RC fun in a BIG way!! Equally at home in bush style flying and extreme 3D, the Big Beaver is also surprisingly precise and offers unparalleled durability. The huge EPP tires easily roll over gravel, dirt, rocks, tall grass, and other airplanes. The unique X-shaped fuselage design adds scale looks in the air as well as extreme stiffness with no need for additional carbon bracing, while the rolled cowl and canopy add to the scale outline and lend tremendous strength to the front of the aircraft.
DESIGN
Designed and developed by Twisted Hobbys team members Chris Jewett and Cody Wojcik, the Crack Turbo Beaver takes the extreme design philosophy that produced the renowned Crack Yak, Crack Pitts, and Crack Laser and gives the Crack treatment to the famous DeHavill and Turbo Beaver bush plane. RCFactory adds their world-class manufacturing techniques and the highest quality EPP foam available. The result is just about as much fun as you can have with an RC airplane! Harriers, hovers, precise knife-edge, rolling harriers, flat spins, snap rolls, and other high-performance aerobatics compliment the traditional loops and barrel rolls you would expect from a high-wing plane. Being nearly indestructible means you can fly between trees, spot-land on your picnic table, and try other crazy things that you'd never do with a balsa airplane.
EQUIPMENT
Equipped with 4-6 servos, a 3s 1350mah battery, and 72 gram motor, the Crack Turbo BIG Beaver is exceptionally versatile and will fly well on a wide variety of equipment and CG placements. Of course, Twisted Hobbys keeps everything simple as always with a proven plug-and-play power combo that provides great performance at a reasonable price. Twisted Hobbys Big Beaver Power Combo Link HERE!!
ADDITIONAL INFO
Although the Big Beaver is an all out do anything monster of a plane, it can be flown on a basic 4ch setup. However, pair your Big Beaver with any computerized radio and 6ch RX and enable flaperons and spoilerons for even more fun and capability! Near-vertical stalled descents with the spoilers up. Incredible upright harriers with the flaps in the up position and even more incredible inverted harriers with the flaps in the full down position. Fly low-speed scale-type flying with the flaps down or use the additional drag of the flaps for extremely high alpha knife edges. And if you like fun-fly style flying combine flap to elevator mix for super-tight loops to add even more depth to the BB's repertoire.
Adding even more capability for the advanced pilot is a new and major innovation with the Big Beaver, Leading Edge Flaps! Leading edge "flaps", unlike leading edge "slats" that are designed to promote airflow over the top of the wing, are control surfaces in the front of the wing. They provide for increased roll authority especially at slow stalled speeds, increased wing angle of attack for those ultra short takeoffs and for harriers they provide even greater drag that promotes better handling by increasing the power setting as well as ensuring the wing is completely stalled reducing the amount of rudder input required to eliminate wing rock. The leading edge flaps are optional and TONS of fun for experienced pilots. They can be operated with a 6ch RX using a Y harness to the ailerons but a 7 or more channel RX is preferred so that each surface can be operated independently.
We recommend the Crack Turbo Beaver and Big Beaver for those pilots looking for an airplane that can do it all. It has an extremely wide flight envelope and is a great tool for expanding your skill set.
AVAILABLE NOW..!!
Red Scheme
Apache Scheme
cdee is offline Find More Posts by cdee
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
DX9 SPM File
Lots of different ways to set this up... but this is a start for those interested.
10 Channel Crack Receiver
Perfect for the extra channels available on the Big Beaver
Old Jun 28, 2015, 06:54 PM
perryleslie is online now
Find More Posts by perryleslie
perryleslie's Avatar
United States, SC, Columbia
Joined Mar 2011
This is going to be epic!
perryleslie is online now Find More Posts by perryleslie
Old Jun 28, 2015, 06:56 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
Grab the snacks, grab a seat, your favorite beverage and get ready... THE BIG BEAVER - EPISODE 1
Enjoy
The Big Beaver Episode 1 (4 min 52 sec)
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Old Jun 28, 2015, 07:12 PM
Benton3dflying is online now
Find More Posts by Benton3dflying
Team Twisted!
Benton3dflying's Avatar
Joined Aug 2012
Just got back flying again the New 43" Big Crack Turbo Beaver, also known as the Big
Beaver. I am flying the stock set-up as seen on the
Twisted Hobbys website. I really enjoyed flying this model
from the start. The plane is a powerhouse! Does great
flat spins, high alpha rolls, hovers well, etc. The short
takeoffs and landings are a breeze. Another fun maneuver is
to taxi fast with the reflex flap position. The four servo
wing allows for rear flaperons and front edge flaps on the leading edge.
This is good for slow high lifting wing performance for
endless acrobatic tricks. The large foam wheels preform well
even on rough grass to rocky roads. Being a big airframe it flies stable in large amounts of wind. I was even flying backwards today with my leading edge and rear flaperons down! Fun times with this amazing new aircraft!
Twisted Hobbys Big Crack Turbo Beaver (4 min 11 sec)
Benton3dflying is online now Find More Posts by Benton3dflying
Old Jun 28, 2015, 07:15 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Reserved
cwojcik is offline Find More Posts by cwojcik
Old Jun 28, 2015, 07:24 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Hey guys,
I finished up my BB tonight and made a little vid about the LEF.
Twisted Hobbys Big beaver - Intro (4 min 5 sec)
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Jun 28, 2015, 07:31 PM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
Great flying Benton...!!
cdee
Old Jun 28, 2015, 07:48 PM
Team Twisted!
Joined Aug 2012
Thanks Cdee,
I can't wait to see some of your videos too! With having both leading edge flaps and trailing flaps in the wing we are going to see wild things with this new plane. Today at the field everybody was swarming around the Beaver. I know I can get more travel out of the control surfaces later but it flies nice at 100 percent throw for now.
Chris, Cody and Aaron will have this plane flipping around soon!
Old Jun 28, 2015, 08:12 PM
jk6672 is offline
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
What are the LE flaps for?
jk6672 is offline Find More Posts by jk6672
Old Jun 28, 2015, 08:17 PM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
Check out the "Additional Section" in the first post... Hercdriver explains them some
cdee
Old Jun 28, 2015, 08:59 PM
Twisted Realm is online now
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
cdee
In short we were able to do things we couldn't with the smaller version. Chris explains it well, the BB is like 3 planes in one, the roll rate capability for a larger top wing plane is very impressive. Its extremely versatile and very user variable. We'll dig into setup and mixing goodies for everyone.
Beaver. We are flying the stock set-up as seen on the
wing allows for flaps and front slits on the leading edge.
even on rough grass to rocky roads. Being a big airframe it flies stable in large amounts of wind. I was even flying backwards today with my slats and flaps down! Fun times with this amazing new aircraft!
https://www.youtube.com/watch?v=XeuSqZ9z2TI
Nice flying Benton!!
Twisted Realm is online now Find More Posts by Twisted Realm
Site Sponsor
Old Jun 28, 2015, 09:42 PM
TEAM TWISTED
Joined Dec 2011
Here are a couple shots of the leading edge flaps on the wing ... the nylon bolts for removing/holding on the wing and of course the BIG wheel with the new wheel collar option installed on the axle.
Latest blog entry: An IMAC EVening from the DJI P3
Old Jun 28, 2015, 10:49 PM
akfreak is offline
Find More Posts by akfreak
United States, NV, Henderson
Joined Sep 2013
Nice new plane.. Great job to the whole Twisted Family
akfreak is offline Find More Posts by akfreak
Old Jun 29, 2015, 01:12 AM
bhoov128 is offline
Find More Posts by bhoov128
John 20:1-18
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Undercambered the wing for some more low speed lift and increased aoa before stall... They're actually called "krueger flaps" and if you ever watch any vids of pretty much any modern fighter, you will see them. The computers on the f18,22, etc, monitor aoa and all that and adjust the le flaps automatically. It's cool to notice on video. Like said before they're not slats, which are movable slots that have an air gap between them and the wing, they just droop the front of the wing downwards.
Sweeeeet plane, great flying Benton!
Btw: did NOT expect leading edge flaps. I thought this would be a big version with split flaps and ailerons. Awesome thinking to get that ultra slow speed bush plane character but keep the full span crazy ailerons.
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Sold NIB Twisted Hobby Turbo Crack beaver what the helli Aircraft - Electric - Airplanes (FS/W) 5 Jun 18, 2015 01:17 PM
Discussion Twisted Hobbies Crack Turbo Beaver jwilliamsrc Foamies (Kits) 10 Oct 21, 2014 02:36 PM
Sold sold Twisted Hobby EPP Turbo Crack Beaver Package porcia83 Aircraft - Electric - Airplanes (FS/W) 3 May 20, 2014 10:57 PM
Wanted Twisted Hobbys Turbo Crack Beaver heliboy04 Aircraft - Electric - Airplanes (FS/W) 1 Feb 02, 2014 05:06 AM
Sold Twisted hobbys crack turbo beaver ERGO60SX Aircraft - Electric - Airplanes (FS/W) 0 Nov 26, 2013 06:07 PM
