Old May 06, 2014, 12:26 PM
Joined Jul 2011
Sunnysky 3508 380KV with 3s 8400mAh?
newbie question. I have 4pcs of this motor (for 5-6S battery) but i have a some
3S 8400mAh that i wanted to use for a quad with big props.
Is it possible or?
tinken is offline Find More Posts by tinken
Old May 13, 2014, 04:58 AM
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
Is it possible or?
You need to specify the All Up Weight. Thrust needs to be at least 2 - 3 weight. So you can look at the 380Kv tables for 3s with different props and it will tell you the thrust per motor.
helidex is offline Find More Posts by helidex
Old May 13, 2014, 05:22 AM
Turkey, Istanbul
Joined Sep 2013
Is it possible or?
3S is possible with large props like 17".
I tried 3s with same motors on Iron Man 650, without any camera and fpv gear, but with 12" props result is it couldnt even hover.
With 4S I was able to hover and get average hovering time, but with zenmuse and gopro, it couldt hover on 4S
With 6S everything works nice but flight time is really bad.
Please note that I made all these with 12". I ordered 15,17" props, waiting to test with them also
DaliOx is offline Find More Posts by DaliOx
Old May 14, 2014, 10:12 PM
Hochiminh City
Joined Mar 2004
It work weel with 3S 17" prop. You neext the esc without sync problem.
http://www.rcgroups.com/forums/showp...&postcount=607
caotri is online now Find More Posts by caotri
Old May 15, 2014, 09:21 AM
Turkey, Istanbul
Joined Sep 2013
did you try your ESC Afro 20A tubes with 4S or 6S setup. Do you think it would be ok to use them ?
Sold Nanotech 3S 8400mah with Traxxas Connector Fidelity101 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Apr 11, 2014 07:48 AM
Wanted SunnySky 3508 380kV, 4108 380kV or similar Jeremy Sebens Aircraft - Electric - Multirotor (FS/W) 4 Mar 12, 2014 07:11 PM
Discussion SUNNYSKY X4108S 380KV Motor .. what ESC? CyberCrash Multirotor Power Systems 2 Jan 28, 2014 03:55 AM
Sold 4x sunnysky 3508-20 kv580 john howard Aircraft - Electric - Multirotor (FS/W) 1 Dec 17, 2013 10:40 AM
Discussion Sunnysky v3508 and tiger 3508 rukie Multirotor Talk 0 Jul 24, 2013 09:28 AM
