Old Jul 18, 2013, 06:13 AM
Joined Jun 2013
Help!
how do i power a 7-12v vtx with a 4s 14v lipo?
hi all
got a problem as i have just purchased foxtech's new vtx vrx set
http://www.foxtechfpv.com/58g-600mw-...rx-p-1118.html
i have a quadcoptor which i power with a 4s 4000mah 25-50c lipo
http://www.hobbyking.co.uk/hobbyking...dProduct=11928
but this pumps out 14volts and the max voltage for the vtx is 12volts.
I was thinking of using a UBEC but they only pump out 5-6v and the low end power requirement for the vtx is 7volts
I dont want to have to add a second battery just for the vtx as this will add extra/unwanted weight to the build.
Anyone got any ideas on how i can step down the voltage to power this vtx from my 4s lipo?
npmullins is offline Find More Posts by npmullins
Old Jul 18, 2013, 02:25 PM
VA
Joined Nov 2009
Originally Posted by npmullins View Post
hi all
The programmable ubecs like the ones from Castle Creations work well. Unfortunately you have to buy the usb linker in addition to buying the ubec. The largest one will do 12v but a little heavy. Dpcav.com has some dc-dc converters that will go higher than 12v but you will have to check power used by tx.
pug398 is offline Find More Posts by pug398
Old Jul 18, 2013, 11:54 PM
New Zealand, Canterbury, Christchurch
Joined Dec 2012
The simple way is with a 12V BEC
http://www.hobbyking.com/hobbyking/s...dproduct=18787
or
http://www.hobbyking.com/hobbyking/s..._7_2_21v_.html
WendoNZ is offline Find More Posts by WendoNZ
Old Jul 19, 2013, 01:21 AM
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
or you can power your tx from the lipos balance plug, just plug it so that it will get power only from 3 cells(12volt)
deno6031 is online now Find More Posts by deno6031
Old Jul 19, 2013, 01:50 AM
Joined Jun 2013
Cool thanks for the help
