Yep, Jazz is right on the scales not having HH on the tail activated. However, if that's your cup of tea, by all means, you may want rate mode because your real heli may be rate mode, I don't know. If you want the scale look and want HH, remember you can tweak that in the model setup.
One other important consideration if you fly the scalies in Phoenix is skid lean during hover. If you fly with a conventional RC heli, most likely the rotor rotates clockwise from top looking down like many European 1:1 heli's. So in a hover, you lean right skid down with some right cyclic to counter the tail rotor thrust. However, if it's a scalie that's a model of a heli that rotates the other way, you will have to lean the other way (usually American 1:1 heli's). Also... don't use the default mCP X ... or probably any of the small submicros - they are not modelled well. |
Joined Mar 2013
Stupid is as stupid does!So, that is why I ask these dumb questions. If you could give me some names of the helicopters, I would know which ones to practice with. Also, I just got the key chain camera and it's charging right now,. Once it finishes charging I will try and attach it to the Blade 120 sr with some velcro and see what happens this time.
Joined Mar 2013
| Thread Tools | |
| Discussion cp helicopter recommendation for under 200$. 200 size or bigger | sniper695 | Micro Helis | 18 | Apr 28, 2013 05:47 PM |
| Mini-Review [New CP Helicopter] Walkera Super CP Mini Review + Unboxing | rctech96 | Micro Helis | 323 | Apr 22, 2013 09:42 PM |
| Walkera Genius CP V2 Rechargeable 6-CH Radio Control Helicopter - DEVO 7 - Gyro | dealextremefan | DealExtreme RC | 0 | Apr 21, 2013 09:09 PM |
