Old Apr 09, 2014, 10:48 AM
*Miss Geigo*
KM.Racing's Avatar
Turkey
Joined Apr 2012
Help!
Servo Problem in my Genesis
Hello guys what's up
please i have a serious problem in my Genesis boat !
when working with 3s battery the system all go right instead when i connect 2 series 3s batteries the servo start giving electricity perturbation sounds and the system don't start :/
when i disconnect the servo and connect the batteries the esc beeps and the system works fine
I'm running stock motor with Hobbyking Boat ESC 120 A . note that i tried 2 servos and different receiver same problem :/
please somebody tell me what's my problem
Best Regards
KM.Racing is offline Find More Posts by KM.Racing
Old Apr 09, 2014, 11:35 AM
CornelP's Avatar
Bucharest, RO
Joined May 2009
If you run on 6S, never rely on the internal bec. Try removing the red wire from the ESC cable and power with a separate battery pack. Most of the "6S" ESCs will have issues with the BEC on 6S...
CornelP is offline Find More Posts by CornelP
Old Apr 09, 2014, 02:16 PM
*Miss Geigo*
KM.Racing's Avatar
Turkey
Joined Apr 2012
hmmm the problem is i wanna run the boat on different batteries not just on 6S i don't want to cut the bec wire :/
Old Apr 09, 2014, 05:51 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
If you run a separate battery pack or BEC you can still run whatever cell count you want. (up to the limits of your ESC and motor) You don't have to cut the red wire either. Here's a little how to for you.
Disabling the BEC on a ESC (5 min 14 sec)
bill34207 is online now Find More Posts by bill34207
Latest blog entry: My "Jet Set"
Old Apr 10, 2014, 08:22 AM
*Miss Geigo*
KM.Racing's Avatar
Turkey
Joined Apr 2012
Oh Bill that's a wise idea thank you so much !
Old Apr 10, 2014, 09:13 AM
*Miss Geigo*
KM.Racing's Avatar
Turkey
Joined Apr 2012
Guys I tired to add an external 4AA batteries to the receiver and I didn't disconnect the red wire from the ESC the boat worked fine on 6s and all parts are alright.
will I have problems in the future ?
Old Apr 10, 2014, 01:43 PM
Joined Apr 2014
Servo
Best to remove red esc wire from connector and tape it bad and don't cut it incase you ever need it, you'll have it. Take your time removing red wire as connector tabs are touchy! I don't know the exact answer but over 4S it's best to remove red wire. I have always used external power in brushed and bl systems and probably old school but always worked. No sense chancing it if it works. OLD timer here.
Whiteout is offline Find More Posts by Whiteout
Old Apr 10, 2014, 03:16 PM
*Miss Geigo*
KM.Racing's Avatar
Turkey
Joined Apr 2012
ah okay well thanks for the advice
and Bill's video is truly the best solution
thank you so much everyone
Old Apr 10, 2014, 06:35 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Eliminating (disabling) the BEC circuit is beneficial to the life of the ESC as it helps cut down on heat build up. The higher the input voltage, the harder the ESC has to work stepping it down through the BEC to receiver voltage.
The old school Castle Hydra's (before ICE series) recommended using separate power for the Rx on anything over 3s.
Old Apr 11, 2014, 11:06 AM
*Miss Geigo*
KM.Racing's Avatar
Turkey
Joined Apr 2012
Awesome thanks for the advice buddy
Old Apr 11, 2014, 05:53 PM
tntpoof's Avatar
Joined Aug 2012
Why dont you remove center wire or red wire and install a Ubec many of those work up to 8 cells and below to 2..Much lighter and lasts as long as your battery
tntpoof is offline Find More Posts by tntpoof
Old Apr 14, 2014, 03:03 PM
*Miss Geigo*
KM.Racing's Avatar
Turkey
Joined Apr 2012
it's a good idea too have to try it after I install my Leopard Motor
Discussion Having problems with my tail servo on tricopter [cracking sound + video] vitallica Multirotor Electronics 0 Apr 01, 2014 05:52 AM
Help! Servo driver problem in need of solution bobbysbrother DIY Electronics 11 Mar 18, 2014 04:03 PM
Discussion Help with my A2 in my Hexa (Yaw Problem) shawnadams Multirotor Electronics 12 Mar 05, 2014 06:31 PM
For Sale *Cracked* Genesis Hull w/ rudder & Servo QYKSLVR Boats (FS/W) 2 Oct 13, 2013 01:45 PM
Discussion Genesis upgrades & have a problem...... mozzyrocks Racing Boats - Electric 14 Mar 04, 2011 10:13 AM
