Old Feb 27, 2014, 08:50 AM
Australia, WA, Perth
Joined Apr 2006
Originally Posted by kimheath View Post
Hi,
I'm interested as to where you are flying - I'm 19k away from you apparently, looks like a nice flying area.
Hi Kim looks like Yokine reserve to me.. I think there are 2 clubs that fly from there.Its a designated flying field & you are covered by MAAA insurance if you are a member of a club & fly there. I used to fly gliders there way back in the 90`s lol
Ian
Ian Thompson is offline Find More Posts by Ian Thompson
Old Mar 03, 2014, 06:39 PM
I'm not lost, they are
pullup!'s Avatar
Co.
Joined Jan 2005
I noticed in the manual on the ailerons its calling for 15mm/30mm then 120% up and 100% down.
Is anyone running aileron differential on there bird?
Got to say its a fun looking little plane!!
UPDATE:
Maidened tonight, no differential was needed. Control throws in manual very mild, upped all surfaces throws. Very fun little bird!
pullup! is offline Find More Posts by pullup!
Old Mar 26, 2014, 02:21 AM
Australia, NSW, Balgowlah Heights
Joined May 2013
Can you run this on 4cell .
farrari is offline Find More Posts by farrari
Old Mar 26, 2014, 02:27 AM
Sed8ed's Avatar
Australia, VIC, Melbourne
Simply put... Sure!
But It doesnt need it.
Sed8ed is offline Find More Posts by Sed8ed
Old Mar 26, 2014, 03:42 PM
United States, TX, Houston
Joined Jun 2012
I have mine back together and flown again this past weekend. 2 batteries and I was like "Homer to dougnuts" and had to put it down and fly my wing. This thing is an extreme blast on a 3S I could not even imagine putting the extra weight of a 4S in it...
continued from:
http://www.rcgroups.com/forums/showp...&postcount=134
formontoya is offline Find More Posts by formontoya
Old Mar 27, 2014, 07:13 AM
Krycek W's Avatar
Canada, QC, Montreal
Joined Jun 2012
I got one too but she still in the box.
Spring is coming here so I will put it together soon.
I think I will put these digital servos in it. http://www.hobbyking.com/hobbyking/s...6kg_0_07s.html
They are not "metal gear servo". Regarding of your experience, what you guys thinking about that?
Krycek W is offline Find More Posts by Krycek W
Old Mar 27, 2014, 12:28 PM
Joined Jun 2012
The specs state 9g micro servos on my PNP and the ARF states the same, neither state metal gear. The plane is not very fast, but it has grunt to the moon, with that in mind I would "assume" you're good.
Old Mar 27, 2014, 03:36 PM
Foam is where the heart is
brett.c's Avatar
Australia, NSW, Como
Joined Aug 2010
The supplied servos on mine are very quiet and smooth, much better than HXT900s etc.
All of mine survived a hard smack into the ground so I guess they pretty durable too.
Not sure if they are available as spares but they may make a good alternative to the other cheap 9g servos on the market.
brett.c is offline Find More Posts by brett.c
Old Mar 27, 2014, 05:31 PM
Sed8ed's Avatar
These are the budget Metal Gears servo's I recently purchased:
http://www.hobbyking.com/hobbyking/s...log_Servo.html
About the only negative would be weight.... they are a little heavier than 9G but the same size as HXT900's. Not a bad price.
Old Mar 27, 2014, 05:45 PM
Krycek W's Avatar
Joined Jun 2012
Thanks all for your comments and suggestions.
So no need for "metal gears". I will go with the speed of the digital servo combine with the possibility of a DSMX RX to go to 11ms of delay with use of digital servos.
I own a couple of 3S-1300mah-20c.
http://www.hobbyking.com/hobbyking/s...idProduct=6308
20c... will be probably limit but OK.
What 3S batt. size are you flying with?
Old Mar 27, 2014, 06:43 PM
Joined Jun 2012
I use Admiral 3S-1300-25C from Motion RC in this and 3 other planes I have and it does great.
http://www.motionrc.com/admiral-1300...-lipo-battery/
Old Apr 01, 2014, 01:16 AM
Joined May 2013
I am using nano 3s 1300 45-90C very good for this plane.
Old Apr 01, 2014, 05:57 PM
That will simply buff out
Boofhead's Avatar
Australia, NSW, Kareela
Joined Jul 2001
Using Rhino 1050mAh 3S 40C and work really well - also use the same in the FunFighter for 3S use
Boofhead is offline Find More Posts by Boofhead
Old Apr 08, 2014, 02:50 AM
Joined May 2013
my H went in nose first, many bits.
Have glued it all back and test flight today all good.
It is not strong plane but can be put back together ok.
New Product Durafly HyperBipe 900mm Sport/3D aerobat MattyB Electric Plane Talk 123 Jan 12, 2014 06:17 PM
Discussion Hyperbipe by Mountain Models patrnflier Parkflyers 5 Nov 09, 2012 09:54 AM
For Sale Masterkit Hyperbipe skylake Aircraft - Fuel - Airplanes (FS/W) 4 Apr 11, 2010 05:21 PM
Video Hyperbipe Cary Reeves Electric Plane Talk 2 Feb 22, 2006 01:18 AM
hyperbipe 3 view flying_pig Scale Kit/Scratch Built 5 Oct 22, 2005 09:12 PM
