Old Jul 18, 2016, 08:34 PM
scififlyer is offline
Find More Posts by scififlyer
Registered Useless
scififlyer's Avatar
United States, TN, Knoxville
Joined Feb 2003
Should I worry about wide-set twins?
If I were to build a twin fan jet with the fans set apart 12"/30cm or more, should I be concerned about the torque of both fans spinning in the same direction?
scififlyer is offline Find More Posts by scififlyer
Old Jul 19, 2016, 01:44 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Does a fan make torque?
henke is offline Find More Posts by henke
Old Jul 19, 2016, 05:23 AM
EDF Shane is online now
Find More Posts by EDF Shane
shane
China, Guangdong, Shenzhen
Joined Dec 2013
The best way to be difference direction.
When the fan getting start I can feel the counter-acting force.
So two fan together should be have difference direction.
Personal idea!
EDF Shane is online now Find More Posts by EDF Shane
Old Jul 19, 2016, 06:27 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
I've never noticed any effect during flight flying twins or singles. ME262, A10,SU34,B737 are some of the models. It isn't worth buying opposite direction fans IMHO.
4stripes is offline Find More Posts by 4stripes
Old Jul 19, 2016, 06:36 PM
Registered Useless
scififlyer's Avatar
Joined Feb 2003
Thanks!
Old Jul 20, 2016, 02:07 AM
Tcoltpilot56 is offline
Find More Posts by Tcoltpilot56
Tail Spin Tim
United States, MI, Warren
Joined Apr 2009
Twin fans
The biggest problem would be asymmetrical thrust should one motor quit. Had a fan blow apart on my A10 without to much of an issue and made a perfect landing with one fan. Check out the MD-11 UPS.
Tcoltpilot56 is offline Find More Posts by Tcoltpilot56
Old Jul 20, 2016, 09:21 AM
bandetlol is offline
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
If they are wide set just mix them with your rudder and do some flat spins with variable thrust.
bandetlol is offline Find More Posts by bandetlol
Old Jul 20, 2016, 01:14 PM
Rich Uravitch is offline
Find More Posts by Rich Uravitch
Rich Uravitch's Avatar
Florida
Joined Sep 2001
No problem with either of my S-3 Vikings, 70mm and 90mm.
Rich Uravitch is offline Find More Posts by Rich Uravitch
Old Jul 21, 2016, 10:21 AM
shane
Joined Dec 2013
May be you are right! But you should notice the rotor of MultiRotor.
The fan just have a shroud to limited the blades and getting small(but the RMP is high).
Most time that just be ignore. EDF F35 jet would notice the effect.
At your Me262 and other jet, you just using your controller to change the small difference so not have any effect and it could ignore.
Both are OK,but I like difference direction twin fan.
Old Jul 22, 2016, 02:58 AM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Large full size turbofan aircraft have their fans turning in the same direction and there is no "critical engine" (unlike prop driven aircraft).
Food for thought...
Old Jul 22, 2016, 10:15 AM
Joined Mar 2015
Food for thought...
Do turbofans have all the individual fans in the compression part rotate in the same direction? They might be spinning in different directions to negate the effect in each turbine,
Also a turbofan is different than an EDF.
Old Jul 22, 2016, 03:22 PM
union1 is online now
Find More Posts by union1
union1's Avatar
United Kingdom, England, Sudbury
Absolutely agree 4stripes.
I've never felt any justification for using 'handed' fan units either.
Reliability of both fans is the important factor, as is setting your flight timer accurately to avoid asymmetric "flame-outs"
union1 is online now Find More Posts by union1
Old Jul 22, 2016, 05:17 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
The only time I have observed any torque effect from an EDF is when the aircraft was in a vertical position at practically zero forward speed. Then the airframe can begin rolling due to the fan torque but with normal flying attitudes and speeds there is no descernable able effect.
A large turbofan engine produces the vast majority of its thrust from the main N1 fan exactly like an EDF. The turbine section in a turbofan is just powering the fan to rotate with some residual efflux as it exits the motor.
To prevent asymmetric thrust I always try to power both motors with the same voltage. Either the same battery powers both or two batteries are running with a parallel connection. This way both motors will turn the exact same RPM and should there be a weaker pack, the stronger pack will balance the voltage in the end.
Discussion Should I be worried about this? Spoon_fork Control Line 17 Nov 03, 2015 06:01 AM
Discussion Something weird about DX7 - Should I worry? Vertical Radios 4 Feb 27, 2007 12:07 PM
Question How worried should I be about this? ferincr Fuel Heli Talk 8 Sep 15, 2006 12:44 PM
Discussion Transmitter upgrade, what should I worry about? Parkflyer Radios 3 Jan 17, 2006 11:41 AM
MM Hellcat: should i just glue it and worry about it later? SHOCKERS Parkflyers 6 Jul 28, 2003 03:49 PM
