Old Apr 04, 2016, 04:18 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Wiper repair
I have wiper damage from fluttering by ailerons on my 4-meter X2. Not exactly sure how to go about repairing those without a large weight gain. Suggestions and experiences would be appreciated.
Darth Latelander... (long story)... May the farce be with someone else.
schrederman is offline Find More Posts by schrederman
Old Apr 04, 2016, 04:45 PM
Joined Nov 2002
Thanks... Now I can get started.
Old Apr 04, 2016, 05:11 PM
Bob McGowan is offline
Find More Posts by Bob McGowan
NorCal
Joined Oct 2003
Half inch transparent scotch tape, one edge adhered to the main aileron and other overhanging edge slipped into the aileron channel is a quick light fix. Baby powder on the floppy part of the tape keeps it from sticking and aids in the tucking-in process. This is the type of wiper many DLGs have used and works fine on a big ship too. That’s how I fix mine, but I may be lazy and not care enough. Can’t get any lighter.
Bob McGowan is offline Find More Posts by Bob McGowan
Old Apr 04, 2016, 10:20 PM
threcixty is offline
Find More Posts by threcixty
Not landing late ever again
threcixty's Avatar
United States, TX, Frisco
Aluminum blinds have about the same curve as most wipers. Use one as a mold to make a fiberglass wiper. Other than that, you can put some tape on the top of the aileron, and make it so it tucks into the bottom of the top wing skin. Mix up some epoxy and microballoons/flox and put that on the inside of the tape, and pull the aileron down. The tape should take the shape of a wiper, and mold the epoxy in the correct shape. Sucks that manufactuers don't use fiber something in their wiper mix!
threcixty is offline Find More Posts by threcixty
Old Apr 05, 2016, 02:37 AM
Phil.Taylor is offline
Find More Posts by Phil.Taylor
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
Here you go - document comb binding stuff worked for me as a mould
http://www.rcgroups.com/forums/showthread.php?t=2095531
Phil.
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Apr 05, 2016, 07:04 AM
mikejr83 is offline
Find More Posts by mikejr83
Scale Aircraft = Scale Crators
mikejr83's Avatar
United States, FL, Gainesville
Joined Jul 2013
If I may ask, how'd the aileron flutter? Bad servo or inadequate torque?
mikejr83 is offline Find More Posts by mikejr83
Old Apr 05, 2016, 01:19 PM
Joined Nov 2002
Aileron flutter generally occurs for me when I have a new model that's the most perfect Xploder I've had, and the lightest, and the best flying... and I'm sleep deprived because I work second shift... and I'm trying to fly off of one of them thar new fangled B winches with that mono stuff that I'm not used to... and I go too deep in the bucket and it goes way faster than I thought possible... because my thumb slipped slightly on the stick... (You believe that... right?)
That's my story... May the farce be with you...
Darth Latelander... AKA Ol' Flabby... Best known these days as PapaJack!
Edit: Thank you all for these inputs... Repairs have begun in earnest...
Old Apr 05, 2016, 03:00 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
Flash Break Tape works great. Get rid of all the molded crap and just use tape. It might even be lighter.
mlachow is offline Find More Posts by mlachow
Old Apr 05, 2016, 04:05 PM
Joined Nov 2002
Mike,
Is that what was used on the tip panels of the Icon 2? I've never heard of Flash Break Tape.
Darth
Old Apr 07, 2016, 07:51 AM
mlachow is offline
Joined Oct 2005
Originally Posted by schrederman View Post
Mike,
Darth
Search amazon
maxi flash break 3.3 mil. 3/4 roll should work.
Not the same stuff as on the old models but it works well. That is what I used for my freestyler.
It also works fine for taping wings.
The other interesting tape you can find on amazon is 3/8 wide 1mil kapton tape that I use for taping on v tails.
Old Apr 07, 2016, 12:46 PM
Joined Nov 2002
Thanks............
Old Apr 25, 2016, 08:27 PM
Hoot is offline
Find More Posts by Hoot
United States, TX, Houston
Joined May 2003
Jack,
Did you finish the wiper repair? I don't understand any of the suggestions to use tape to repair a wiper. I need photos to figure it out. Now I've looked at the photos and still don't quite get it.
S Gibson
Hoot is offline Find More Posts by Hoot
Old Apr 30, 2016, 11:54 AM
Joined Nov 2002
I have the correct tape but right now I haven't the time to do anything. I've been blitzed with server/switch/router cut overs at work and with grand children visits... (currently about to be blitzed by Nora and Eli within the next hour) One hundred eighty five days... to freedom!
Darth Disgusted...... The farce is strong with this one...
Old Apr 30, 2016, 07:55 PM
threcixty's Avatar
If you are feeling lazy, my Helios DLG flew better without wipers... So did the Stobel.. ... ...
Discussion mcpx bent servo wiper brooks33 Micro Helis 1 Mar 29, 2016 09:30 PM
Discussion Scale Wipers and Handles catcat Scale Helicopters 19 Oct 17, 2014 03:38 AM
Discussion Flap wiper rebuild/repair Phil.Taylor Multi Task F3X 11 Feb 10, 2014 06:13 AM
Discussion No more windshield wipers? dll932 Life, The Universe, and Politics 10 Dec 18, 2013 01:13 AM
Help! F3F moldie - wiper/wing skin repair Phil.Taylor Slope 7 May 17, 2010 06:02 AM
