Old Mar 07, 2016, 06:59 AM
prutealex is offline
Find More Posts by prutealex
I'm probably not a potato!
prutealex's Avatar
Denmark, Region Syddanmark, Odense
Joined Aug 2015
Build Log
T960 Heavy lift dodecacopter
This build started a while ago. (I think it was last year in October)
But some stuff happened.
This should probably be able to carry like 15-20kg payload with no batteries. I am using these motors http://www.ebay.com/itm/281519696721...AIT&rmvSB=true with 1855 propellers which should give me at least 3.5kg of thrust with 22.2v
The frame is a tarot T960 COPY http://www.ebay.com/itm/T960-Multico...35f&rmvSB=true (not the real tarot because Hobbyking didn't have them in stock)
I will be using the Foxtech Pivot v3 landing gears and these ESC http://www.ebay.com/itm/221605136380...AIT&rmvSB=true
The motors will probably draw about 300-360 amps on full throttle in total so Im using this power board http://www.uavshop.co.uk/catalog/pro...roducts_id=383
All this will be powered by four 10 000 Mah making a total of 40 000 Mah.
I hope to get around 20-30 mins of flight time
The dodecacopter is about 5kg and 5kg batteries. So there should be room for 10-15 kg payload.
The copter's maximum takeoff weight should be around 25 kg on 70% thrust if the coaxial setup makes it 20% less efficent.
prutealex is offline Find More Posts by prutealex
Old Mar 10, 2016, 08:09 AM
Cereal_Killer is offline
Find More Posts by Cereal_Killer
I void warranties
United States, OH, Columbus
Joined Dec 2014
This is not correct. A PROPERLY setup coax setup provides ~5% MORE efficiency than a flat configuration but you have to properly size the motors / props. Having the same IS NOT correct. You need to have a ~1" smaller diameter, and 1.5" higher pitch prop on the bottom. If that's not possible you need to spin the lower prop faster.
The inefficiency figure you mention (that I'm guessing you read here) is only if you're using the same prop / motor upper and lower which causes the lower to freewheel in the upper's downdraft. It also takes away a bunch of control authority.
Read this
http://ecalc.ch/calcinclude/help/xco...help.htm#hints
Cereal_Killer is offline Find More Posts by Cereal_Killer
Old Mar 11, 2016, 01:58 AM
prutealex's Avatar
Joined Aug 2015
To be honest I don't really need more thrust. But thanks for the tip.
Also got my landing gears on the copter.
Old Mar 17, 2016, 02:33 PM
Thengine is offline
Find More Posts by Thengine
United States, MI, Rochester Hills
Joined Jun 2015
Can you provide a source for this increase in efficiency? Having 2 props on top of each other will reduce efficiency, regardless of size and pitch. This is because they BOTH have a much larger induced drag because of the downward velocity imparted to the air by the other motor.
Read this
Thengine is offline Find More Posts by Thengine
Old Mar 31, 2016, 02:02 PM
prutealex's Avatar
Joined Aug 2015
Getting ready for maiden.
Old May 05, 2016, 12:56 PM
zatorax is offline
Find More Posts by zatorax
zatorax's Avatar
Russia, Saint Petersburg, СПБ
Joined Sep 2015
nice work!
zatorax is offline Find More Posts by zatorax
Old May 06, 2016, 12:19 PM
prutealex's Avatar
Joined Aug 2015
Originally Posted by zatorax View Post
nice work!
holy crap I thought you were gone forever.
Build Log T960 Heavy lift dodecacopter prutealex Scratchbuilt Multirotors 2 Mar 07, 2016 07:02 AM
New Product Foxtech T960 Heavy Duty Hexacopter COMBO glassfox Multirotor Talk 8 Oct 16, 2013 11:23 AM
Cool Foxtech T960 Heavy Duty Hexacopter COMBO glassfox FPV Aircraft 0 Aug 23, 2013 02:01 AM
For Sale Heavy lift DJI heavy lift system with 50 point waypoint Nytram Aircraft - Electric - Multirotor (FS/W) 2 May 11, 2013 02:30 PM
Sold AD-6 Heavy Lift V2?AD-6 Heavy Lift frame+Photo higher Pro Mount-200 iranbarkley Aircraft - Electric - Multirotor (FS/W) 7 Jan 15, 2012 02:32 PM
