Old Aug 30, 2013, 10:48 AM
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Question
Nano and RFU for 3-Axis Heli Gyro System
XPS,
I am considering purchasing a Thunder Tiger 450-class heli that comes with an ACE GT5.1 3-Axis gyro system. The manual for the GT5.1 gyro says that it will accept inputs from a regular receiver with discrete cabling for each servo. The manual also says that the gyro will accept a PPM or S-Bus stream through a single lead. The attached diagram is from the GT5.1 manual; here are my questions:
1. Would the Nano-II go to the same port as the S-Bus Rx shown circled in the diagram?
I've read that the Nano-II can talk S-Bus, PPM, and "Xtreme" protocols.
2. Which of the three protocols above would you recommend for this application?
Please advise. Thanks,
Paul
FlyingW is offline Find More Posts by FlyingW
Old Aug 30, 2013, 10:56 AM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
The Nano II can output PPM or Xtreme, not SBUS. So, you will need to use PPM for this setup.
JimDrew is online now Find More Posts by JimDrew
Old Aug 30, 2013, 01:39 PM
FlyingW's Avatar
Joined Dec 2001
Thanks Jim.
Beside less cabling from the Rx to the gyro, is there any electronic or signal advantage to using a serial PPM stream?
Paul
Old Aug 30, 2013, 11:21 PM
Lake Havasu, AZ
Joined Jun 2005
Nope, no advantage other than a cleaner installation.... but that is a big deal because you can remotely locate the receiver.
Old Aug 30, 2013, 11:23 PM
FlyingW's Avatar
Joined Dec 2001
Thanks Jim,
Paul
Old Sep 02, 2013, 05:59 PM
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
There's a definite advantage to PPM mode if the gyro can use more than 6 channel inputs. In PWM (standard) mode the Nano is limited to 6 channels but in PPM mode you're only limited by the number of channels in the TX.
I'm controlling 8 channels on a multirotor with a Nano and a Futaba 9CAPS, but the single-wire connection 'tween the Nano and gyro is an awfully nice bonus.
Pete
PGR is offline Find More Posts by PGR
Old Sep 02, 2013, 06:10 PM
Lake Havasu, AZ
Joined Jun 2005
Awww... true! I forgot about extending the number of channels too!
Old Sep 30, 2013, 10:54 PM
FlyingW's Avatar
Joined Dec 2001
Still investigating new 3-axis gyros for flybarless heli operation.
I think I was wrong about the ACE GT5.1 and its ability to accept a serial PPM stream - it can take the individual discrete receiver outputs from a PPM receiver using a cleverly reduced set of cables, but it cannot take a serial PPM stream. It can accept a serial SBUS stream, and it can also use Spektrum satellites.
Can folks here kindly identify a flybarless gyro product that will accept a serial PPM stream from the Nano-II? I'd like to see how the vendor describes the connection.
Paul
Old Oct 01, 2013, 09:30 AM
Lake Havasu, AZ
Joined Jun 2005
BeastX can accept CPPM (composite PPM), SBUS, Spektrum satellite, or standard receiver channel inputs.
Old Oct 01, 2013, 11:15 AM
FlyingW's Avatar
Joined Dec 2001
Thanks Jim. Very interesting - they call it a "composite signal receiver." Now I know one way to ask the gyro vendors the question of whether they support the feature.
Paul
Old Oct 22, 2013, 07:28 PM
FlyingW's Avatar
Joined Dec 2001
Another question concerning the composite PPM signal available from the Nano:
Does the Mikado Mini-VBar support the Nano's composite PPM signal?
I'm waiting to be approved for the Mikado VBar Forum, but in the meantime I thought I'd ask here.
Paul
Old Oct 22, 2013, 09:35 PM
Gotta Luv Gasser Helis..
_Peter's Avatar
Gold Coast, Qld , Australia
Joined Apr 2006
A tad off topic , but BeastX is lots easier to setup, no computer needed for setup OR any adjustments....
And probably only 1% of pilots would notice any difference in flight characteristics.......
_Peter is offline Find More Posts by _Peter
Old Oct 22, 2013, 10:45 PM
Lake Havasu, AZ
Joined Jun 2005
PPM is PPM, so it works with any device that supports is PPM, including the Vbar.
Old Oct 23, 2013, 08:30 PM
FlyingW's Avatar
Joined Dec 2001
A suggestion I got in the Mini-VBar forum was to try the single line PPM setup and see if there were errors in the log after giving all of the possible stick and switch movements. I suppose that's reasonable.
Say the single line PPM works fine, and I have it wired as the diagram below. The ESC's internal BEC feeds power to the Mini-VBar through the RX-B connection. Both RX-B and RX-C are on the Mini-VBar's power bus.
Can the Nano-II be powered through its connection to RX-C?
Thanks again,
Paul
Old Oct 23, 2013, 11:07 PM
Lake Havasu, AZ
Joined Jun 2005
Yes.
Discussion Hobbyzone TGZ380 Flybarless 3 Axis Gyro System kgd1 Mini Helis 799 Yesterday 11:31 PM
Discussion Anyone need a 3-Axis Gyro System for Fixed Wings? hobbypartz Nitro Planes 0 Jun 26, 2013 02:04 PM
Off Site 3 CopterX (CX-3X1000) Flybarless 3-Axis Gyros, USB, Bluetooth Adaptors Heli stretch1100 Aircraft - General - Radio Equipment (FS/W) 6 May 25, 2013 11:05 PM
Discussion $25 FBL Dynam 3GS 3 AXIS GYRO SYSTEM N8LBV Mini Helis 3 May 19, 2013 11:44 PM
Sold Align 3GX nib 3 axis gyro flybarless system viper7 Aircraft - Electric - Helis (FS/W) 0 Feb 24, 2013 11:33 PM
