Old Jan 18, 2015, 07:32 PM
roverroberts's Avatar
United States, GA, Newnan
Joined Jan 2011
Saito 100 low speed needle
I inadvertently adjusted the low speed needle on my Saito 100 thinking it was the screw to remove the throttle arm. What is a good starting point to get things back running smooth?
roverroberts is offline Find More Posts by roverroberts
Old Jan 18, 2015, 07:47 PM
tacx's Avatar
United States, FL, Naples
Joined Apr 2009
If you have the plastic throttle arm the surface of the screw should be 1/16 th inch below the flat surface of the throttle arm.
tacx is offline Find More Posts by tacx
Discussion saito FA91 high speed needle valve......need part number big_poppa4904 Engines 2 Oct 29, 2014 08:57 PM
Question Where is the low-speed needle valve on my FS-91?? shamrock1990 Engines 2 Jun 24, 2014 07:28 PM
Discussion Low needle setting for Saito 100 jcflyrc Engines 7 Apr 01, 2007 11:54 PM
Discussion Saito 150 Low Speed Needle edkoz Engines 3 Jan 08, 2007 11:48 PM
Discussion Saito 72 - Having trouble setting low-end needle rhagen Engines 10 Oct 17, 2006 12:24 PM
