Old Dec 11, 2014, 08:51 PM
United States, SC, Boiling Springs
Joined Apr 2014
Speed Challenge
Me and a few friends have a speed challenge. We are going to build 4 identical Flite Test Racers, we all get to pick our own motor esc and prop. We cant go higher than a 4s battery.
Chuckwhite is offline Find More Posts by Chuckwhite
Old Dec 12, 2014, 02:26 AM
Defies Logic & Common Sense
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
So this is gonna be a test of engineering and materials since your gonna use similar airframes.
speedactyl is online now Find More Posts by speedactyl
Latest blog entry: Hover conversion
Old Dec 12, 2014, 12:46 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Do it like they do with the full size airplanes, install the biggest, baddest motor that will fit in the airframe. Then use the largest diameter prop that will fit with enough blades to max out the power of the motor.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Dec 12, 2014, 01:14 PM
Joined Apr 2014
That's the plan, lol
Old Dec 12, 2014, 02:13 PM
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
A powerful high kv motor with a high pitch prop will give you speed , but reducing drag and weight will also make a big difference . Make it as streamlined as you possibly can , and leave out unnecessary weight such as the swappable pod and rudder servo . You won't need the rudder for high speed flying .
balsa or carbon is online now Find More Posts by balsa or carbon
Old Dec 12, 2014, 09:31 PM
speedactyl's Avatar
Joined Jun 2012
Larry
Sounds like a GeeBee R2 small plane with Big engine and just enough wings to fly
Old Dec 12, 2014, 09:45 PM
Dukejet's Avatar
Australia, QLD, Biloela
Joined Aug 2012
What frame have you's decided upon?
Dukejet is offline Find More Posts by Dukejet
Old Dec 13, 2014, 08:18 AM
Joined Apr 2014
Were using the Flite Test Racer
Old Dec 16, 2014, 09:49 PM
Dukejet's Avatar
Joined Aug 2012
Luvly little frame. Ft racer/ slinger $36 for the kit. Is that the one?
Old Dec 18, 2014, 07:30 AM
Dukejet's Avatar
Joined Aug 2012
Ordered the kit! ....
Old Dec 22, 2014, 03:12 PM
Christian F
CaliPilot's Avatar
United States, CA, Redwood City
Joined Mar 2011
Cover the airframe in packing tape. a lot less friction than paper and foam!!
CaliPilot is offline Find More Posts by CaliPilot
Old Dec 28, 2014, 05:18 PM
Dukejet's Avatar
Joined Aug 2012
I was planning to go with iron-on HK covering film(brushed crome)..
Well I'll do a test an see how it goes.
Old Jan 06, 2015, 10:41 AM
Dukejet's Avatar
Joined Aug 2012
My FT Racer turned up unscathed! I thought for sure the shipping would kill foam sheeting.
I have a Turnigy 1450Kv 3536 with an 8x8 prop, Alloy spinner,50amp ESC, will see how she balances with a 3000 4s may have to be content with 2650 3s. Hmmmmm so many options
Old Jan 21, 2015, 08:19 AM
Dukejet's Avatar
Joined Aug 2012
FT Racer complete -- motor/ESC tested today -- Over 1000W @ 73amps driving a 8x8!
Next--Maiden and into the paint shop. Then photo shoot...
News ARRMA — Beat The Speed Video Challenge Paul Onorato Car Talk 1 Feb 26, 2014 11:24 AM
Contest 2010 Flat Foam Speed Challenge: Top speed is JIMBAKER at 91.0 mph The Don Foamies (Scratchbuilt) 986 Jan 23, 2011 12:23 PM
Discussion Brushless Speed / Torque of challenges, the MKS 760μs with AVCS impression your idea fuhsong Electric Heli Talk 24 Aug 07, 2009 12:57 PM
Contest International R/C Speed Challenge, October 4th 2008 @ Rockingham N.C. b4maz Car Talk 2 Aug 31, 2008 11:28 AM
Aquacraft Top Speed 2 Team Challenge at IMPBA and NAMBA 2005! AMCross Racing Boats - Internal Combustion 0 May 27, 2005 02:30 PM
