Old Jun 22, 2015, 02:30 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Question
Are the Beaver strus mandatory
Are the wing struts on the Hangar 9 30CC Gas Beaver really necessary?
I have broken 3 of them in less than a month. The keeper on the low end falls out and the strut hangs down so it gets broken when you land.
There is a stout wing tube and 1/4 20 bolts holding the wing. I have flown around with the strut hanging down, knowing it would be destroyed on landing without noticing and wing flexing.
Has anyone flown without these struts? At the price I can't keep replacing them every week.
Fokker DII is offline Find More Posts by Fokker DII
Old Jun 22, 2015, 08:57 PM
dusturbd is offline
Find More Posts by dusturbd
Joined May 2015
I cant say about the hangar9 but I have a 109" aeronca and you can tell the wing sags a little when you remove the strut.
I wouldn't fly without them.
dusturbd is offline Find More Posts by dusturbd
Old Jun 22, 2015, 09:21 PM
Leroy G is offline
Find More Posts by Leroy G
Leroy G.
Leroy G's Avatar
Coeur d' alene, Id.
Joined Jan 2010
Good rule of thumb is if the real plane had them then put them on especially on wings over 30".
Leroy G
Leroy G is offline Find More Posts by Leroy G
Old Jun 23, 2015, 02:26 AM
David Hogue is online now
Find More Posts by David Hogue
Go Dawgs!!!!!!!
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
The manual will probably tell you, but I bet you didnt read it!
David Hogue is online now Find More Posts by David Hogue
Old Jun 23, 2015, 08:43 AM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
The manual does not say if the struts are necessary or not. They assume we will use them. The manual DOES SAY that the strut is EASILY BROKEN. But they don't have a fix!!!
I ask because the 3D Hobby Shop 84" Big Foot has a problem with the struts coming apart. The manual says they are functional,
However: The forum on that plane is full of people who fly WITHOUT the struts. A plane at our field does full on 3D without the struts. So I wondered if the Beaver had the same capability>>Not 3D Though LOL.
Old Jun 23, 2015, 09:18 AM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Replace the struts with removable flying wires. However if the struts are coming loose figure out a way to secure them ie a small piece of fuel tube to keep a clevis closed
jetmech05 is offline Find More Posts by jetmech05
Old Jun 23, 2015, 10:07 AM
barracudahockey is offline
Find More Posts by barracudahockey
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
What is coming apart? I don't have any problem with mine.
barracudahockey is offline Find More Posts by barracudahockey
Old Jun 23, 2015, 01:04 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
The spring clip that goes through the pin gets loose and falls out. We can order "spares" from Horizon at $10 + for a couple of them. They lose their "spring" after a couple of uses then just fall out.
When that happens the strut hangs straight down and it is impossible to land without breaking it at the wing end. I have broken 3 of them in a couple of weeks. The replacements are about $26+. Real PITA. I would expect better from H9.
I tried using a 4x40 bolt and a nilock nut to replace the pin/body clip as supplied, but it is nearly impossible to get it together without dropping the nut inside the gear fairing. PITA again.
Old Jun 23, 2015, 01:31 PM
Joined Sep 2004
If you place a bit of fuel line on the clevis pin it will put tension on the cotter pin.
Small cotter pins can be had in bulk from anywhere that sells RC car stuff, they hold the bodies to the cars.
Old Jun 23, 2015, 05:22 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Thank you for the tips. The problem may go away, and hopefully car body pins are cheaper than H9 wants for them.
I have the same problem with the pins on the Pawnee also, but the strut does not hang down and get broken.
Old Jun 26, 2015, 12:20 AM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
I tried the fuel line to provide tension today.
WELL, the pin popped out during the first taxi to the runway. Needless to say that cost me Yet ANOTHER of those PITA H9 struts!
This is the worst design yet out of China!
Old Jun 26, 2015, 01:22 AM
Go Dawgs!!!!!!!
USA, NC, Clayton
Joined Feb 2001
Can we get some pics of your plane with the struts and pins installed? There's no reason for the body pins to just pop out, as there's no tension on them
Old Jun 26, 2015, 05:47 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
THE SPRING CLIPS that are supposed to keep the pin in place fall off allowing the pin to fall out with vibration.
The "spring" is No Good. After a couple uses they open up and do NOT grip the pin. They are made of CHEAP SOFT material.
The problem is NOT the Pin, it is the Spring cotter key that holds the pin in.
I have ordered a couple extra seta of these, since they are easy to drop and lose, They get $10 for 4 of the things and none of them hold their shape after a few uses. They ARE NOT spring steel like they should be.
Old Jun 26, 2015, 07:43 PM
Joined Sep 2004
Car body cotter pins then
Old Jun 26, 2015, 10:20 PM
Go Dawgs!!!!!!!
USA, NC, Clayton
Joined Feb 2001
or paper clips or regular cotter pins. they wont fall out till you make them come out
Discussion Arizona lawmaker (GOP) wants to make church attendance mandatory Tim Green Life, The Universe, and Politics 108 May 12, 2015 11:18 AM
Discussion beavers are for flying,then turning into fur coats alex5 Scale Fuel Planes 1 Aug 01, 2009 09:08 AM
Sold 90 deg ret. W/ strus and servo captainpitts Aircraft - General - Miscellaneous (FS/W) 3 Jun 14, 2009 08:45 PM
Is It Mandatory? emaxximan Fuel Plane Talk 7 Aug 19, 2003 01:05 PM
Sellers full disclosure.. Should be mandatory flyin' Brian Site Chat 4 Jul 14, 2001 10:15 PM
