Old Jul 01, 2015, 09:24 AM
JBuck is offline
Find More Posts by JBuck
JBuck's Avatar
United States, CA, San Diego
Joined Apr 2007
Originally Posted by DeadstickDuck View Post
Illustration
OK , so how did you get the elevator arm to face UP?
Mine is facing down per the stock setup. Do I just cut it out and glue in a new one?
JBuck is offline Find More Posts by JBuck
Old Jul 01, 2015, 09:28 AM
DeadstickDuck is offline
Find More Posts by DeadstickDuck
Electric
Joined Oct 2009
Yes, that is right. This mod along with getting rid of the rudder servo opens up sooooo much room inside, removes any flex, moves weight rearward to allow bigger batteries (anything that physically fits that is such as a 3s2250 45C lol.......) and reduces dead weight of the steel control rods. Drag caused by the external elevator servo is negligible since it's in line with the vertical stab.
Basically free mods using scrap building materials.
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Jul 01, 2015, 09:29 AM
JBuck is offline
JBuck's Avatar
Joined Apr 2007
Go for the cobra 2221-12 with its 4mm shaft (RCDude) and Aeronaut 8x7 with the BB 30/4/8 turbo spinner (Esprit Models)
Save up for the Talon35 and enjoy it as well. The motor/esc/spinner/blades together are less than what a nice dinner and movie out with the wife costs..., So treat yourselves.
What makes the 2221-12 better than the 2217-12?
The specs look similar, 2221 is a little less kv and about 15 grams heavier.
Wouldn't the lighter motor with higher kv be better?
Thanks again, Im loving my Kunai
Electric
Joined Oct 2009
Yup, easy with a sharp blade, flip it over and add new epoxy
Old Jul 01, 2015, 10:09 AM
Electric
Joined Oct 2009
Sounds logical but the smaller 2217-12 motor is going to get really hot spinning the 8x7 on 4s, has 3.2mm shaft and needs more throttle control.... You're pulling 38 amps lol. Oh, and you need a 35A esc (IMHO the Talon35),. Envision a turbocharged 2.4L engine putting out 300hp... Which is still like doubling the stock 170hp motor.... In visualization terms.
The longer 2221-12 will handle more, thicker 4mm shaft that will handle any bumps. It only needs a Talon25A for those that have one already ..... This motor also handles 3s If you put on an AR10x8 Envision the 6.4 v8 putting out 425hp.
Bigger is better.....for that 15 grams extra weight. And why having the elevator servo outback counters that weight! Muahahahha
4s is JPL
Old Jul 01, 2015, 10:34 AM
JBuck is offline
JBuck's Avatar
Joined Apr 2007
Sounds logical but the smaller 2216-12 motor is going to get really hot spinning the 8x7 on 4s, has 3.2mm shaft and needs more throttle control.... You're pulling 38 amps lol. Oh, and you need a 35A esc (IMHO the Talon35),.
The longer 2221-12 will handle more, thicker 4mm shaft that will handle any bumps. It only needs a Talon25A for those that have one already ..... This motor also handles 3s If you put in an AR10x8
OK, you convinced me.
Old Jul 05, 2015, 04:13 PM
fluxcapacitor121 is offline
Find More Posts by fluxcapacitor121
The Future is Gnar
fluxcapacitor121's Avatar
Joined Dec 2011
Kunai wing set for sale Sold
Sold
If anyone needs a new wing set, I have one for sale. The covering needs to be repaired or replaced. $35 shipped.
Complete listing with a bunch of pics-
http://www.rcgroups.com/forums/showt...3#post32077440
fluxcapacitor121 is offline Find More Posts by fluxcapacitor121
Old Yesterday, 11:02 AM
JBuck is offline
JBuck's Avatar
Joined Apr 2007
What do you guys think is the best CG for the Kunai?
Old Yesterday, 11:21 AM
Fentonflyers is offline
Find More Posts by Fentonflyers
United States, MO, Fenton
Joined Jan 2012
I have mine set neutral. Meaning that inverted I barely have to push.
Fentonflyers is offline Find More Posts by Fentonflyers
For Sale DG808S 4m/157'' Glider ARF For $269 richyan Aircraft - Electric - Airplanes (FS/W) 1 Apr 25, 2014 01:38 PM
Discussion Video - FPV perspective during aerobatics with a 4m glider mustang_jmz FPV Talk 5 Jan 10, 2014 10:55 AM
Discussion Venturi new 4m glider by CBmodélisme CBmodelisme Sailplane Talk 5 Oct 14, 2013 12:12 PM
Sold 3-piece DB9 Wing Wiring Harness for 3M to 4M Glider TDboy Aircraft - Sailplanes (FS/W) 0 Sep 26, 2013 01:47 AM
Discussion 4m Glider - Electric Upgrade KarbonBird Electric Plane Talk 3 May 23, 2009 11:09 PM
