Old Mar 25, 2015, 07:46 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
btw im working on a large f15 for twin edf should have it ready way before az jets if you make it this year..
corsair nut is offline Find More Posts by corsair nut
Old Mar 25, 2015, 10:54 PM
gbmoore is offline
Find More Posts by gbmoore
Colorado Springs, Co
Joined May 2002
Heck yeh I'll be there! I need the face time with Larry to give him a ration!
('scuse me while I go drool.....'15's!!!! )
gbmoore is offline Find More Posts by gbmoore
Old Mar 25, 2015, 11:04 PM
tehachapi, CA
Joined Jan 2006
highly modded byron...scale gear..full gear doors...full ducting..no cheater holes..and re shaped inlets and stab tips. its not perfect scale but a whole lot better
yes...its sitting a little high.need to dial in the stance a bit
Old Mar 26, 2015, 05:35 AM
mike2663 is offline
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Nice!
mike2663 is offline Find More Posts by mike2663
Old Mar 27, 2015, 05:47 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Originally Posted by rvincent View Post
Where's Andy? Haven't seen him in any threasds for quite a while?
I still come sniffing around the R/C airplane sites once and while. My A-4 still fly's great but she hasn't got much attention lately..busy doing other stuff.
falcon5 is offline Find More Posts by falcon5
Old Mar 27, 2015, 06:34 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Good to hear from you!
rvincent is offline Find More Posts by rvincent
Old Mar 27, 2015, 10:31 PM
Reco is offline
Find More Posts by Reco
RC Fanatic
Reco's Avatar
USA, NC, Greensboro
Joined Mar 2002
Good to hear from you...Miss watching your mega builds...
Reco is offline Find More Posts by Reco
Old Mar 28, 2015, 05:48 PM
xplaneguy is offline
Find More Posts by xplaneguy
Clear Skies & Contrails
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Andy,
Great to see you lurking around RCG!
See you in 7 months!
Best,
Tony
xplaneguy is offline Find More Posts by xplaneguy
Latest blog entry: RutanRC at RCX 2015
Old Apr 21, 2015, 12:55 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Off topic but didn't want to start a thread for a video.
Snowbirds TankCam (4 min 40 sec)
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Apr 27, 2015, 07:03 PM
Viper1957 is offline
Find More Posts by Viper1957
Joined Mar 2003
Questions regarding 88" A-4 Skyhawk
This 88" long A-4 is a very impressive EDF!
I plan to build a 90mm EDF version and have a few questions that I hope someone such as Falcon5 or A10pilot can answer.
Are the overall shape and the wing/fuse/horizontal stab proportions based on the Bell Models A-4 plan? If so, were any changes made?
Was the flat bottom airfoil shown on the Bell plans used or was it modified?
Did anyone build washout into the tips or is washout not necessary on this model?
Was the bottom of the leading edge rounded at all?
Where is the center of gravity on the wing? (I couldn't see it on the Bell plans).
I assume the top of the wing is completely flat/straight (front view) per the real A-4?
I have seen a few suggestions regarding wing and horizontal stab incidence. If the bottom of the wing is 0 degrees and the stab has approximately 1 degree of "up", would that work? This is what I have done on past scratch-built models.
Thanks in advance!
Cheers!
Viper1957 is offline Find More Posts by Viper1957
Old Apr 27, 2015, 08:48 PM
A10pilot is offline
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Schertz
Joined Mar 2006
Thanks in advance!
Cheers!
Mike:
I don't recall all of the answers to all of your questions above but I will try to answer some.
1. I did use the John Bell plans blown up to the appropriate size.
2. I did use the wing profiles on the Bell plans. I used the flat bottom airfoil and about 1 deg. of washout. My plane flew very well and landed very nicely without flaps.
3. The leading edge was rounded but flat on the bottom to conform/meet the flat bottom airfoil.
4. I do not recall the CG location but mine (and I believe Andy's (falcon5) were posted in the thread.
5. Top of the wing as flat.
6. Incidence was: Wing at +1 deg. positive (leading edge up) and the stab was at zero deg. with the wing at +1.
I will see if I can find the CG.
Ed
A10pilot is offline Find More Posts by A10pilot
Old Apr 27, 2015, 09:23 PM
Joined Mar 2003
Thanks for the info, Ed!
I recall reading that you cut your wing halves in 3 sections. Did you add washout only to the outboard section? It's too bad that washout is necessary because foam cutting is a whole lot easier if you can leave the bottom perfectly flat and only cut the top of the wing! Do you know if Andy used washout? I believe he hand sanded the wing's airfoil shape.
I also read that Andy moved his c of g back a few times so I'm not sure where the "sweet spot" ended up.
Thanks again!
Old Apr 30, 2015, 08:21 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
nice vid EW good to see you in here
AIR SALLY is offline Find More Posts by AIR SALLY
Old Apr 30, 2015, 09:13 PM
A10pilot is offline
A10pilot's Avatar
Joined Mar 2006
Thanks again!
Mike:
I cut the wing in four sections. Center section out to just past the gear, and then from there to the tip. As I recall, I just drew the washout on the wing from the center line of the wing out to the tip and then cut each of the four sections individually. I can not find any of my notes on the location of the CG but it was what Andy ended up as he flew his before I did so I just took his CG location.
Ed
Old May 01, 2015, 12:10 AM
Joined Mar 2003
Thanks Ed! I think I now have all the information I need.
Cheers!
Build Log A-4 Skyhawk 90mm Oryon Electric Ducted Fan Jet Talk 40 Apr 22, 2014 07:39 AM
Discussion 3DHS Slick 88" and Extra 88" servo help please Jiffy 3D Flying 7 May 05, 2013 09:43 PM
Discussion How long does a 4 stroke glow plug last jeff262 Engines 5 Feb 17, 2013 01:33 PM
Sold Yellow A-4 Skyhawk Doug Bateman Aircraft - Electric - Jets (FS/W) 13 Jan 18, 2013 07:30 AM
For Sale 4 CH 2.4GHz BlitzRCWorks A-4 Skyhawk Pro Radio Remote Control dunne44 Aircraft - Electric - Jets (FS/W) 7 Aug 07, 2011 09:16 AM
