Old Aug 13, 2012, 08:24 AM
"ARF LOVER" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Thanks a lot ... as I suspected completely different from the one I have.
wollins is offline Find More Posts by wollins
Old Aug 14, 2012, 09:37 PM
The Hun in the Sun
vonJaerschky's Avatar
Comox, British Columbia, Canada
Joined Nov 2003
I've recently used Tamiya flat clear in a spray can and it works really well. It's lacquer based, so definitely test first over the paint you are using to make sure it doesn't ruin the finish. I had no problems used over enamel and also Warbird Colors acrylic paint. The cans are small, so you may need more than one. I just put on a very light coat on top of an FMS Stuka, and it didn't really need very much at all. Testors Dulcote in a spray can might work for you, too.
vonJaerschky is online now Find More Posts by vonJaerschky
Old Aug 14, 2012, 11:19 PM
wollins's Avatar
Toronto Canada
Joined Aug 2004
Thanks! And BTW good luck on your maiden of the 109 tomorrow!
Colin
Old Aug 15, 2012, 09:21 AM
The Hun in the Sun
Joined Nov 2003
Thanks Colin! Man, is everybody watching?
Old Feb 03, 2013, 11:42 AM
Land O' Lakes, FL
Joined Aug 2003
I used the Krylon flat clear on monokote and it blushed horribly, leaving an ugly greyish splotchy finish. Any ideas on how to avoid this? Don't tell me about humidity. I live in Florida!
sailr is offline Find More Posts by sailr
Old Feb 03, 2013, 01:48 PM
wollins's Avatar
Toronto Canada
Joined Aug 2004
Did it do this immediately or over time? And what "version" are you using?
Colin
Old Feb 03, 2013, 03:44 PM
Land O' Lakes, FL
Joined Aug 2003
It blushed immediately even though I tried to go with light coats. Version? I only know of one version, FLAT CLEAR.
Old Feb 03, 2013, 04:27 PM
wollins's Avatar
Toronto Canada
Joined Aug 2004
See I think this is where the problems lie ... there are so many versions of Krylon clear that when someone says "theirs" does or doesn't work the confusion still lingers. I've heard as much people say "it" works for them as those that have said "it" doesn't work. Attached are just four of the versions that I have discovered. You will notice that they all have one thing in common ... they are all basically "flat/matte" clear.
So which do you have?
Colin
Harry H's Avatar
Los Angeles
Joined Oct 2010
I think he was referring to the fact that Krylon has changed the formula thus -another version. I use the flat a lot and have never had any problems with it regardless of version. You do need to shake it up really good to make sure the flatteners are mixed good and keep shaking between sprays.
Harry
Harry H is offline Find More Posts by Harry H
Old Feb 04, 2013, 10:09 AM
Land O' Lakes, FL
Joined Aug 2003
Harry,
I have the first one, on the left that has two cans in the picture...the one marked "FLAT". I have never seen the other two available around here. Which have you used with success?
Old Feb 04, 2013, 10:24 AM
Harry H's Avatar
Los Angeles
Joined Oct 2010
I just looked and have both. The one on the left is the newer version and I just used it on a new plane to dull it down and it went on even with a great finish. I was surprised it didn't react to some enamel I used. I sometimes use a heat gun on a lower setting to dry between coats.
Harry
Old Feb 04, 2013, 10:33 AM
Land O' Lakes, FL
Joined Aug 2003
Did you apply it over a monocote/ultracote type covering? That's where I ran into trouble.
Old Feb 04, 2013, 06:08 PM
Harry H's Avatar
Los Angeles
Joined Oct 2010
Yes, Ultracote, glossy plastic, parts painted with enamel, parts painted with latex....and it looks good on everything I have put it on raw Ultracote and Ultracote that I scuffed up with 0000 steal wool. Didn't seem to make any difference. Hope this helps.
Harry
Old Feb 05, 2013, 07:45 AM
Aurora Municipal, Illinois, United States
Joined Jul 2002
I've painted over covering with Krylon rattle cans and had pretty good luck so far. I mask off an area to paint then I use a scotchbrite pad to scuff the area to be painted. I follow up with a wipe with mineral spirits to degrease and remove any sanding dust.
For a flat clear coat I recently bought a can of testors dullcote to test on covering. It's lacquer based so I don't know what it will do to the covering or if it will be fuel proof.
bullseye000 is offline Find More Posts by bullseye000
Old Feb 05, 2013, 05:51 PM
Land O' Lakes, FL
Joined Aug 2003
I guess I'll just have to try again. I think my problem here was the humidity.
Discussion 1k or 2k clear coat?or gel-coat? krikkens Composites Fabrication 39 Jul 14, 2012 08:06 AM
Discussion Flat clear coat - nervous!! John Pilot Scale Boats 7 Jan 27, 2010 01:27 AM
Discussion Rattle can Clear coat dry time Raydee Painting and Finishing Tips 0 Jul 20, 2008 08:19 AM
What type/brand of flat clear coat do you use?? spitfirem9 Slope 9 Apr 30, 2004 11:53 AM
