May 18, 2013, 02:30 PM
Michigan's Upper Peninsula
Joined Sep 2007
I'm no technician on motor/prop combos, but I'd try a 12 inch prop and run it up with your watt meter before you fly. If it pulls too many amps, I'd step up to the TB 36 and give it a try. I kind of follow an 80% rule. If I'm pulling more than 80% of my max amp rating, I move up to a higher rated ESC.
I normally climb to around 600 before I shut down. I get about 5 good, strong climbs from my 900mAh battery. That only eats up about 300 mAh or less.
Again, I'm no technician. I just experiment until my plane gives me what I want.
Dave
