Old Dec 14, 2013, 02:11 PM
Thomas B.'s Avatar
Germany, Nordrhein-Westfalen, Cologne
Joined Mar 2012
Build Log
Swift
Here is a free download for my swift / Mauersegler bionic depron design.
span is 68 cm, flies great on 2 or 3 s lipo with 20 g motor.
http://modell-aviator.de/modelle/dow...n-mauersegler/
Mauersegler bei Regen (2 min 15 sec)
Mauersegler reloaded (1 min 18 sec)
Thomas B. is offline Find More Posts by Thomas B.
Old Dec 14, 2013, 03:00 PM
United States, CA, Folsom
Joined Jun 2011
Pls post details
radhav is offline Find More Posts by radhav
Old Dec 15, 2013, 01:52 AM
Slopeosapien
jonesymj's Avatar
Joined Jun 2006
That's really awesome! I have a new years day fly-in I go to every year, and this would be perfect for it! I couldn't figure out how to download the plans, tho... I'm not new at this "internet" thing, but could you maybe post a direct link to the download? I would very much like to build one!
Either way, that's a great website. There's at least a couple different flying things in there I'd love to build!
jonesymj is offline Find More Posts by jonesymj
Old Dec 15, 2013, 04:20 AM
Thomas B.'s Avatar
Joined Mar 2012
Try this:
http://modell-aviator.de/files/downl...rsegler_a4.pdf
Please let me know ift it works.
Old Dec 15, 2013, 05:14 AM
Thomas B.'s Avatar
Joined Mar 2012
How to build it
It is a very quick build. You can finish it in an evening.
You need:
5 or 6mm Depron
Skewers for pushrods and control horns
4 x 1 or 5x1mm CF spar or 5x 2mm wood
4mm ply for the firewall
two 5 or 9g servos
15 - 20 g outrunner
2s or 3s lipo, 500 - 900 mAh
Old Dec 15, 2013, 05:19 AM
All can fly...Launch stronger!
ttersu's Avatar
France, Centre, Romorantin-Lanthenay
Joined Oct 2013
Thanks, Subbed!
ttersu is offline Find More Posts by ttersu
Latest blog entry: My builds
Old Dec 15, 2013, 06:00 AM
Thomas B.'s Avatar
Joined Mar 2012
Build #2
It is definitely one of my favourite models and still in service after many flights. Very easy and smooth flying, even in heavy winds.
Old Dec 15, 2013, 06:16 AM
Thomas B.'s Avatar
Joined Mar 2012
Finishing
C of G is 110 mm from firewall (not leading edge!), no up trim is needed. Elevator throw is + - 30mm, aileron 45 mm, measured at tip.
I use a turnigy 2211/2300 with 3s 800 mAh Lipo and a 4,75 x 4,75 prop.
Old Dec 15, 2013, 10:30 AM
Slopeosapien
jonesymj's Avatar
Joined Jun 2006
Yes Thomas, that link worked perfectly! Thanks!
Now it's time to print and build!
Old Dec 15, 2013, 12:33 PM
Canada
Joined Nov 2000
That is Great! thank you.
Bare is offline Find More Posts by Bare
Old Dec 15, 2013, 03:16 PM
Joined Jun 2011
What us your all up weight including your 3s 800 ?
My son and I cut bluecore wing and a $tree kfm step. 9g servo is what we have - have a 1300kv blue wonder - might be too low kv...
Old Dec 15, 2013, 04:47 PM
Thomas B.'s Avatar
Joined Mar 2012
All up weight is around 220 g. Your motor will be fine with the right prop.
Old Dec 15, 2013, 11:15 PM
Joined Jun 2011
i also have one of these - http://www.hobbyking.com/hobbyking/s...outrunner.html
might use this instead
Old Dec 16, 2013, 11:44 AM
Thomas B.'s Avatar
Joined Mar 2012
This will work fine for moderate speed with 3s and 7x 3,5 prop or a bit slower on 2s with 8 x 4. The white bird at the end of the second video in post #1 has a similar setup.
Old Dec 23, 2013, 10:29 AM
Joined Jun 2011
Thanks to Thomas - my son had a blast.
Airframe: Bluecore fuse/wing with $tree foam KF step
Motor: blue wonder clone 1700kv
Prop : GWS 8040
ESC: 18 amp
Battery : 3s/450mAH
cell phone video...
Blue Core Swift (0 min 59 sec)
Sold Tech One Swift EPP Plane kit + AS2814 motor + ESC + 11g servo + propeller jhurault Aircraft - Electric - Airplanes (FS/W) 7 Dec 23, 2013 06:43 PM
Discussion help with hk mini swift with mini 2000kv suppo need prop advice eagleyez Micro Ready-to-Fly 0 Dec 14, 2013 01:16 PM
For Sale 2 Brand New Swift 50 amp ESC Great for Twin smurf Aircraft - Electric - Power Systems (FS/W) 2 Dec 11, 2013 08:37 PM
Sold Repost Swift S1 MiBD RLTBULLDOG Aircraft - Sailplanes (FS/W) 1 Nov 28, 2013 08:53 AM
For Sale Swift S-1 jacktrotter Aircraft - Sailplanes (FS/W) 6 Nov 26, 2013 03:45 PM
