Old Mar 18, 2014, 01:04 PM
United States, NY, Kings
Joined Oct 2011
I have Gliderdrive sk3 1400kv
11x8 prop draw 57A on the bench.
10x6 prop draw 30A on the bench.
czynot is offline Find More Posts by czynot
Old Mar 18, 2014, 01:16 PM
LI, New York, USA
Joined Mar 2003
3S I presume - what capacity and C rating on the pack?
aeajr is offline Find More Posts by aeajr
Old Mar 18, 2014, 02:18 PM
Joined Oct 2011
Double post
Old Mar 18, 2014, 02:19 PM
Joined Oct 2011
Yes. Genace 1350/ or 2200 3S 25C
Old Mar 18, 2014, 02:46 PM
LI, New York, USA
Joined Mar 2003
Careful, you are over drawing the 2200 and WAY over drawing the 1350 if you re using it for the 57 amp run. I suspect you are getting big voltage drops.
Old Mar 18, 2014, 04:25 PM
Joined Oct 2011
Yeah. I didnt know it pull that much amp till i tested it with a meter. I guess i will have to down size the prop. 11x8 alot more thrust than 10x6.
Old Mar 18, 2014, 04:31 PM
Little Red Plane
United States, TN, Knoxville
Joined Dec 2012
Or just use a correctly rated ESC.
GarryOgilvie is offline Find More Posts by GarryOgilvie
Old Mar 18, 2014, 05:27 PM
Joined Oct 2011
Yes i can put in bigger esc. I have 100A ESC, but thats not the problem.
like arejr said. I will pulling too much amp out of the battery. Max amp from 1350 25C lipo is 33A. Max amp from 2200 25C is 44A. I am pulling 57A on the bench. In the air, It should pull less amp than on the bench. Gliderdrive SK3 Motor is rated at Max 47A.
I will get my batteries pregnant in no time.
Old Mar 18, 2014, 05:40 PM
Little Red Plane
Joined Dec 2012
Yeah your are right. I missed that you were using the 25C battery.
I've been using the Heads Up 50C batteries, they work really well for the price. Their 1300mAh 50C is rated for 65amp continuous and 130 max.
Old Mar 18, 2014, 09:25 PM
LI, New York, USA
Joined Mar 2003
Still he is over amping the motor. If you were hitting 50 for 30 seconds you would probably be fine but 57 could put you in overheat land.
Old Mar 21, 2014, 02:04 PM
1984 is no longer fiction
War is Peace's Avatar
United States, FL, Sun City Center
Joined Mar 2012
Update: I've been using my Turnigy Glider Drive motor for 2 months. (3858-840kv with 12.5x7.5 Aeronaut CAM prop on 2200ma 3-cell lipo) I must have well over 100 launches on it.
Still running cool and smooth. I'm very happy with this motor.
War is Peace is offline Find More Posts by War is Peace
Discussion Turnigy Aerodrive SK3 OR NTM Prop Drive Series OR easy match series sebbe Power Systems 10 Dec 23, 2012 02:33 PM
Discussion Turnigy D or SK3 series? jtaylor996 Power Systems 2 Nov 29, 2012 09:25 PM
For Sale Turnigy Helidrive SK3 Competition Series 4 NIB blawren Aircraft - Electric - Helis (FS/W) 0 Nov 21, 2012 10:51 AM
For Sale Turnigy G60 and Turnigy SK3 4250 fnlrun Aircraft - Electric - Power Systems (FS/W) 3 May 21, 2012 12:20 PM
Mini-Review New Turnigy Sk3 Series Outrunners, Turnigy's "High end" Outrunner daign Multirotor Talk 20 Apr 26, 2012 04:28 PM
