Old Jul 29, 2014, 10:10 PM
Lockey is online now
Find More Posts by Lockey
Tony Audsley Retired Locksmith
Lockey's Avatar
Australia, WA, Perth
Joined Sep 2011
Cri Cri
You can blame this on my good mate Loco1 ... thanks Kev
Thought it would be good to have a play with a fun one for a change after the Mosquito ... although I do seem to sometimes run into problems with the "fun models"
Anyway, here goes nothing ... any interest on this one?
Anyone with any experience with the Junkers style flap / aileron please jump in with some advice / help / comments
I did a search and it seems no one has done a scratch build of this one
Quite a bit of info around on this one … Only difference, I will be designing the “electric” version of it as shown in the pics below
http://www.flight.cz/cricri/english/...escription.php
http://www.cricri.zoomshare.com/6.html
Lockey
Lockey is online now Find More Posts by Lockey
Old Jul 29, 2014, 10:53 PM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
A truly unique project, Lockey!
Will you have a bit of dihedral as seen in the pictures?
djacob7 is offline Find More Posts by djacob7
Old Jul 29, 2014, 11:02 PM
Lockey's Avatar
Joined Sep 2011
Thanks dj, I will be building it as close to scale as possible, the full size one has 4 degrees on each wing ... this is what I will be doing
Does anyone know if there is a "minimum" distance you can have between twin props ? if I go with 8" props, they will be fairly close together (about 40 - 50 mm between)
Lockey
Old Jul 30, 2014, 02:28 AM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
My neck-top computer says that 40 to 50 mm will be plenty for the prop clearance.
For aerodynamic reasons I would have the prop tips traveling downwards as the pass each other.
Whiskers is online now Find More Posts by Whiskers
Old Jul 30, 2014, 03:33 AM
Loco1 is offline
Find More Posts by Loco1
Callington South Australia
Joined Mar 2006
What sort of span you thinking of Tony?
Loco1 is offline Find More Posts by Loco1
Old Jul 30, 2014, 04:04 AM
Lockey's Avatar
Joined Sep 2011
Thanks Whiskers
Was working on a HUGE 1/4 scale Kev ... which works out about 1250 mm (actually 1225, but I added a bit for good measure)
Lockey
Old Jul 30, 2014, 06:23 AM
tonystro is online now
Find More Posts by tonystro
TonyS
United States, AR
Joined May 2010
Tony, as always I look forward to your fabulous results.
Decades ago, I and a buddy worked out Junkers-style flaps for a sport flyer; balsa built up 500 sqin wing, about 4.5-5 lbs, K & B .40 power. They worked, rather well even, but not noticeably better than "standard" flaps on nearly identical model. We believed the extra design/construction effort was not rewarded by improved performance. Further, our one attempt at Junkers-style ailerons (outboard 1/3 of wing half) induced twisting. We also believed the reinforcing added to prevent the twist negated any gain in efficiency.
An major improvement/advantage the Junkers-style surfaces offer is the reduction in controlling force necessary to move the surface. I don't believe we can utilize this advantage in RC. However, you may well find a way!
TonyS
tonystro is online now Find More Posts by tonystro
Old Jul 30, 2014, 06:39 AM
Lockey's Avatar
Joined Sep 2011
TonyS
Thanks for that Tony, might not be worth the trouble then
Do you know if there are any set parameters in relation to the wing ? ... out from the back or distance from the bottom of the wing etc
I was thinking aileron / flaps (flaperons) as on the real one
Lockey
Old Jul 30, 2014, 09:49 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Lockey,
Have you seen this 100% scale Cri Cri flying indoors. Mesmerizing!! Best of luck with your project, the Cri Cri is a very cool little plane.
modell-hobby-spiel 2011 - CriCri in Action (2 min 9 sec)
leadfeather is offline Find More Posts by leadfeather
Old Jul 30, 2014, 10:09 AM
Lockey's Avatar
Joined Sep 2011
Originally Posted by leadfeather View Post
Lockey,
https://m.youtube.com/watch?v=OWI9PhuIRFY
Yes seen it mate, very clever eh
Lockey
Old Aug 03, 2014, 04:23 PM
Draggin'Tail is offline
Find More Posts by Draggin'Tail
USA, IL, Belleville
Joined Sep 2008
I would love to see you do this one next. I saw that video a couple years ago. Great size at almost 50". Bring on the plans, Mate. Always love your builds. The Cri Cri has some similarities to a Moni , i.e. rectangular wing and a box/ tub style fuse. I've wanted to do a foam Moni someday.
Draggin'Tail is offline Find More Posts by Draggin'Tail
Old Aug 04, 2014, 07:40 PM
Lockey's Avatar
Joined Sep 2011
I stalled on this mainly because of the wing and the Junkers style flaperons, I was going to go with a section similar to the real one (top pic)
I have decided to drop the Junkers and go with a std aileron (flaperon) and a Clark Y (ish) style wing section
Any comments or suggestions ?
Lockey
Old Aug 06, 2014, 09:52 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
This one is going to be a Right Side Up flyer anyway, so Clark y is good to go .
Bob
birdofplay is online now Find More Posts by birdofplay
Old Aug 07, 2014, 06:33 AM
Lockey's Avatar
Joined Sep 2011
Almost there with the drawings, now for the plans
Lockey
Old Aug 07, 2014, 05:35 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
Good lookin' drawings as usual Lockey!
Dave-
foamdave is offline Find More Posts by foamdave
News HobbyKing Cri-Cri Twin Matt Gunn Electric Plane Talk 77 Mar 22, 2016 05:36 PM
Review HobbyKing Cri-cri PNF Review DismayingObservation Scale ARF/RTF 13 Aug 10, 2015 04:34 AM
New Product HK Cri-Cri Boofhead Foamies (Kits) 2 Jul 09, 2014 07:10 AM
Discussion Cri-cri IWC Scratchbuilt Indoor and Micro Models 12 Jan 20, 2014 09:53 PM
Discussion I don't know whether Uncle Walt would have laughed or cried dll932 Life, The Universe, and Politics 2 Nov 04, 2013 07:30 PM
