Espritmodel.com Heli Air
Old Jul 23, 2012, 02:21 PM
USA, TX, The Colony
Joined Dec 2005
Originally Posted by BadLemon View Post
cquian
I got about the same setup you have a stumax 80mm with a Het 1680 built buy Stu. I fly from a grass field as well, what retracts are you using? I need to buy them next.
Recommended eFlite retracts but with TAMS upgraded struts
cquian is offline Find More Posts by cquian
Old Jul 23, 2012, 07:54 PM
nippaero's Avatar
Nampa, ID
Joined Oct 2009
Is there anyone selling the Jetfan 80 in the US?
nippaero is offline Find More Posts by nippaero
Old Jul 23, 2012, 10:27 PM
Richmond B.C. Canada
Joined Aug 2006
Got mine here.http://www.performance-edf.biz/newjetfan80jetfan90.html
172AMD is offline Find More Posts by 172AMD
Old Jul 23, 2012, 10:28 PM
Sponsored by Team de la Peņa
bdelapen's Avatar
Miramar, FL
Joined Aug 2008
http://www.rcgroups.com/forums/showt...0#post21906145
- Birger
bdelapen is online now Find More Posts by bdelapen
Old Jul 23, 2012, 10:34 PM
nippaero's Avatar
Nampa, ID
Joined Oct 2009
Thanks. I must have missed this somewhere. How's the flight report on the Jetfan?
Old Jul 24, 2012, 04:51 AM
texas
Joined May 2005
Originally Posted by cquian View Post
I use a Futaba T12FGH, have crow set up using the CAMBER MIX menu. You program a switch (I use a 3-position switch SG). On position 3 for landing, I have the ailerons go up, full flaps, elevators go down. Can't remember the exact settings, but you enter in percents required to get the amount of up or down you want per surface. I did not use any Y connectors so I could fully control each servo from the radio which of course required my 14 channel receiver
But it works very good, and landings are ridiculously slow and easy with my current crow settings.
So how much actual throw do you think you are using with crow ?
Not percentages ....
Tks
rcfun2005 is offline Find More Posts by rcfun2005
Old Jul 24, 2012, 08:12 AM
Ireland, Co. Dublin, Dublin
Joined Feb 2012
I tried 5mm and it was good but our patch is quite short so landed up going for 7mm to pull it up a bit quicker. It does tend to drop at the end though so if space is not an issue 5mm is quite comfortable.
Hope that helps.
Quandry is offline Find More Posts by Quandry
Old Jul 24, 2012, 08:25 AM
texas
Joined May 2005
Hope that helps.
hey thanks that helps alot...
so did you have to put any up or down elav in also ?
Old Jul 24, 2012, 09:52 AM
USA, TX, The Colony
Joined Dec 2005
You will need some down elevator with full flaps deployment.
Old Jul 24, 2012, 11:36 AM
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
Awesome! Sounds great and has lots of power. I've done 2 now. One on 8s with a HET 700-68-1680 and one on 10s with a HET 700-68-1500.
swps is offline Find More Posts by swps
Old Jul 24, 2012, 05:19 PM
Joined Feb 2012
I already had the eflite recommended amount of down elevator with full flaps. I didnt change anything for adding crow. I could be wrong but the whole plane seems to float like crazy with full flaps and crow. Almost hard to get it down now!
Old Jul 24, 2012, 08:13 PM
Joined Dec 2007
Here's how I put crow in on the 12FG. I used dual AIL servos and a Y harnessed flap.
Go to MODEL menu
Then PROG. MIXES
These first 2 mixes are for the MID FLAP and FULL FLAP elevator down. The next two are the crow (1 mix for each AIL servo). SEE PICTURE
Then I show the 3 menus in each of the crow mixes. The OFFSET on the first menu is what adjusts your crow amount. Note that I have slowed the servo down to 20. This is to reduce the ballooning from applying instant flaps/crow (I also have the flaps slowed down).
switzer is offline Find More Posts by switzer
Old Jul 25, 2012, 07:18 AM
Joined Mar 2005
Go to MODEL menu
Then PROG. MIXES
switzer,
Thx Tony
T-spin is offline Find More Posts by T-spin
Old Jul 26, 2012, 12:39 PM
Joined Dec 2007
Maidened my habu last night. Couldn't get off our grass field so went down the road to an asphalt field. Flew great and landed super easy.
Question is that it doesn't seem to have much a$$. Running stock setup with a 4 yr old flight power 25c 6s. That batt is old, but was never used. What's the hot 6s pack now? Or should I just jump up to 7 or 8 cell? Running the Phoenix ice 100.
Old Jul 26, 2012, 01:02 PM
Team Futaba
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Go to MODEL menu
Then PROG. MIXES
Switzer there is an even easier way to acheive the flap to El mix and the crow setup on the 12FG. Happy to share both setups.
Bob
Robert Belluomini is offline Find More Posts by Robert Belluomini
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
