Old Apr 09, 2014, 04:36 PM
Joined Mar 2014
Transmitter Lipo
So I got the recomended lipo for the turnigy 9xr and was wondering if I should treat this like any other lipo, or if I can leave it connected, or not at storage voltage. Thanks.
shambopyro is offline Find More Posts by shambopyro
Old Apr 09, 2014, 05:13 PM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Transmitter lipos aren't the same as main packs used in the model.
freechip is offline Find More Posts by freechip
Old Apr 09, 2014, 05:51 PM
Joined Mar 2014
could you be more specific? Thanks for the quick reply though.
Old Apr 09, 2014, 06:14 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
You can leave it fully charged in the tx for extended periods of time and the resulting increased resistant in them won't matter much since the current demand on them isn't big like packs used for powering the motor on the model.
If you want more info on the subject the battery section of the forum might get you better answers then mine.
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
A proper transmitter LiPo would be a low-C (usually 3C to 5C) pack. They are usually lighter and smaller than the same capacity High-C pack. The low-C packs do not suffer from puffing when stored fully charged for prolonged periods of time.
I would not recommend to use a 3S LiPo in a transmitter designed to use 8-cell NiCd or NiMH. A 3S LiPo in a transmitter maintains around 11.8-12.0V for quite awhile (several hours after being fully charged) while an 8-cell Nickel pack quickly drops below 11.5V under typical transmitter load. The higher voltage of the fully charged 3S LiPo put unnecessary thermal stress on the voltage regulators (3.3V in modern transmitters) inside the transmitter. A 3S LiFe is a much better match for such transmitters. The 3S LiFe nominal voltage of 9.9V is much closer to the 9.6V nominal for a Nickel pack.
Another advantage of LiFe is that they are a lot more stable then LiPo and as a result a lot safer.
Ivan
ivanc is offline Find More Posts by ivanc
Old Apr 10, 2014, 08:06 AM
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
I prefer Lithium Tx batteries and have used a 3 cell LiPo pack in my JR XP9303 for years, without issue. There are many who reduce the voltage either by charging to a lower voltage or using Radio Shack diodes, in series, to drop the fully charged voltage from 12.6v to 11.6v or so. I am now using LiFe Tx batteries. A 3 cell pack stays at 9.9v and dies not drop off until just before full discharge. Like all Lithium packs, they are light, charge fast, and the charge holds for months.
I have a DX8 with a LiPo pack. Flying almost every day, I can charge and go two months without charging again. This beats NiCad/NiMh/Eneloop.
Buschbarber is online now Find More Posts by Buschbarber
Sold Futaba T9chp super 9- ch transmitter, w/ receiver, lipo battery & lipo charger LADYHAWK13 Aircraft - General - Radio Equipment (FS/W) 0 Nov 26, 2013 01:35 PM
Sold Futaba T9chp super 9- ch transmitter, w/ receiver, lipo battery & lipo charger LADYHAWK13 Aircraft - General - Radio Equipment (FS/W) 0 Nov 23, 2013 10:39 PM
For Sale Transmitter Lipo Battery - New Steve_O Aircraft - General - Radio Equipment (FS/W) 2 Oct 06, 2013 09:05 AM
Sold Transmitter and Lipo Safe Bag RG916170 Aircraft - General - Miscellaneous (FS/W) 0 Oct 01, 2013 04:42 PM
Discussion 20% OFF All Gens Ace Transmitter+Receiver LiPo packs GensAceUSA Hot Online Deals 1 Sep 29, 2013 01:14 AM
