Old Mar 04, 2014, 10:43 AM
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Originally Posted by Cathurga View Post
I was thinking of having a mould made of the cowl, and then having it done in lead :-)
LOL
It's not that bad.
This is what the Zero got and a pound of lead went on the underside way up front. It weighed in at 15 pounds and flew good with the DLE30
scootrb4 is offline Find More Posts by scootrb4
Old Mar 13, 2014, 03:01 AM
teamwork, do it my way!
Dubai, UAE
Joined Jun 2007
Ok, so I have made some progress on the Tiffy. This plane is driving me demented and I needed the help of a mate to add a new perspective on it. As it is, we managed to do some tweaking to get it in a state closer to airborne.
Here are some pics. As you can see I have mounted EVERYTHING as far forward as possible to eliminate need for too much weight, but it will STILL require some I am sure.
In this pic, you can see the hole I cut behind the firewall. The gear and ign batteries are attached to the firewall in the lower right of the pic. You can see the venturi stack poking into the area behind the firewall. On the left is the gear and ign switches, charging jacks and fuel dot. The Rx is mounted on a plate above the frontal area. I have some concerns with it so close to the ign, but the thing has run with no apparent glitching.
In the next pic, I built a basic hatch for access to charging fuelling and to install the avionics pack before flight. The avionics pack will just install on the inside of the hatch. It is a 'hatchet' job (see what I did there, lol) and will be improved once I know it flies. The cowl is not mounted, just placed.
Here is a view with the access hatch open for remedial works. The firewall will also have a mount inside the hatch to the right so that the cowl has a resting platform in order to reduce strain on the cowl mounting screws. More to come.....when, I don't know....
Cathurga is online now Find More Posts by Cathurga
Old Mar 13, 2014, 07:06 AM
scootrb4's Avatar
Joined Nov 2011
The hatch is a good idea, I am utilizing the same space in my Corsair for ignition and batteries. Good to see the Tiffy getting some attention. Keep it coming.
Wanted ESM Typhoon stevehookem Aircraft - Fuel - Airplanes (FS/W) 0 Apr 23, 2013 10:57 AM
Discussion ESM Spitfire 89" - first gasser... TBone08 Giant Scale Airplanes 15 Jun 08, 2012 07:57 AM
Build Log Kmp/Esm. 1/5th Pilatus PC 21 45cc Gasser soundgecko Giant Scale Airplanes 7 Apr 13, 2009 11:12 AM
Sold 30cc gasser on E.I.--REDUCED! JEanes Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jun 15, 2007 10:36 AM
Sold 30cc gasser JEanes Aircraft - Fuel - Engines and Accessories (FS/W) 13 Apr 02, 2007 07:53 AM
