Old Feb 04, 2015, 03:46 PM
zippomaker is offline
Find More Posts by zippomaker
Joined Feb 2013
Help!
How to control DYS 3axis gimbal with Attitude Head Tracking?
Hello everyone, I'm trying to control the 3-axis gimbal DYS (with alexmos) through headtracking of Fatshark Attitude.
For the moment, few results ....
Dys Gimbal + Spektrum DX8 + Fatshark Headtracking test (0 min 27 sec)
in the first video I show you how usually I control the gimbal, the channel with trimmer, AUX3 control the pitch, with the switch 3 positions and a Mix on radio I control 3 positions of YAW: 0- + 45°-45°
Dys Gimbal + Spektrum DX8 + Fatshark Headtracking test 2 (0 min 23 sec)
in the second video I linked the Fatshark through Trainer port and apart which moves in the opposite direction, I can not control the pitch ... why?? ..
The trainer from the radio I set that controls AUX3 but I do not know why I can control only YAW,
What should I set?
thanks
zippomaker is offline Find More Posts by zippomaker
Old Feb 05, 2015, 02:17 PM
Joined Feb 2013
Iset AUX3 for the Pitch and GEAR for the YAW
If I set the Trainer with AUX3 only, the YAW works (wrong..... should works the Pitch), if set also GEAR , nothing works....
help
Old Feb 09, 2015, 07:19 AM
Joined Feb 2013
Now the problem is that the two parameters (YAW and PITCH) are not controlled simultaneously by headtracker…
If in Spektrum Trainer's submenu I active channel n°5 (GEAR/YAW), the headtracker control correctly the YAW
If in Spektrum Trainer's submenu I active channel n°8 (AUX3/PITCH), the headtracker control correctly the PITCH
but if I active channel 5 and also 8 does not work yet nothing….
What can I do?
thanks in advise
Old Jun 04, 2015, 12:04 PM
Yellowihss is online now
Find More Posts by Yellowihss
United States, TX, Leander
Joined Apr 2013
Did you ever figure this out?
Yellowihss is online now Find More Posts by Yellowihss
Discussion A good radio for the use of the attitude v2 with trinity head tracking ATXgreen FrSky 0 Jan 10, 2015 08:03 AM
Discussion Trinity Head Tracking with H3-2D Gimbal and Futaba 10J TANNMANN FPV Equipment 1 Dec 04, 2014 08:39 PM
Help! How to stabilize the 3axis gimbal with 8bit Basecam controller for Canon 5D Christian Lynn Multirotor Electronics 2 Dec 03, 2014 04:38 AM
Discussion DYS 3axis BL gimbal with SONY FS100 Agris Multirotor Talk 0 Oct 05, 2014 04:34 AM
New Product DYS Alexmos BaseCam 3axis 32bit Brushless Gimbal Controller Quadframes Multirotor Talk 6 Jul 22, 2014 06:54 PM
